#11 |
Hi again
Iām a bit confused. I thought these tubes were rather sought after for Audio applications. Are they not? I not what is the problem with them? Thanks again Peter |
#12 | |
If there's a sucker born every minute, where do the rest of them come from? |
#13 |
Hi again.
Thanks for replying SY. OK - lets say that I am the ritch guy who has 25 of these - what is the going rato for them? I have seen prices og 50 -85 USD on the web - but that was the A version. What brand is the beast. The fact that they are limited in supply does make them unrealistic for commercial use - not for DIY/costum use. I am still not sure if I should by all i can get of these or let them go? Thanks again |
#14 | ||
diyAudio Senior Member
As an investment you'd really need to find a desperate customer as the 6C33-C is a real cheap alternative and other than some industrial applications (transmitters) I really don't know many people using this type. Quote:
Frank |
#15 |
I haven't bought them in a while, so I can't really comment on price. AFAIK, they were all made by the same company, so the branding is merely decoration.
#16 |
Penta Labs is selling them for 85.20$ which is certainly not excessive given the industrial application and warranty that comes with it. Mind you, these could very well be made in China as some of the 6336(A)s I've come across. Not necessarily a bad thing but I'd still prefer the Raytheons for audio useage. Cheers,
Frank |
#17 |
I got two 6528 recently. Well! They are pretty great, arn't they!
I plan to build a single tube amp, cause I'd got a DAC with quite high output level, nearly 5V rms! The only problem is the OPT. One guy told me that the OPT need 200R, not 2K or 1K. Gee! Where can I got that kind OPT? He said the plate resistence of 6528 is 80R, but the resistence I calculated, according to datasheet, is about 200R. Am I wrong? |
#18 | |
BTW, 6C33C have a plate resistance of 80ohm and seems to be performing best with a load impedance of 600ohm, maybe he mixed up 6528 and 6C33C. Morgan Jones have described a SE amp with 6528 in his book if I remember correctly, check what impeadnce he is using. Regards Hans |
#19 |
Thanks! Tubetvr.
I remember that the plate resistence is not a fixed value. Is it different according to the different working point? For example, using differnet B+ and plate current, then got different value of plate resistence. Am I right? |
#20 | |
Regards Hans |
| How much difference 0.22 vs 0.33 cap? | pengboon | Tubes / Valves | 1 | 1st July 2007 10:07 AM |
| difference between 1 and 2 | androtaker56 | Car Audio | 9 | 14th November 2005 12:36 PM |
| Difference between CDM 4/19 and CDM 4/19/31 | bezobraznia | Digital Source | 1 | 28th October 2005 10:08 AM |
| I2C/I2S,what's the difference??? | Leolabs | Parts | 2 | 18th April 2005 01:20 PM |
| What's the difference? 2.83V/1m - 1W/1m | 1Time | Everything Else | 5 | 10th February 2003 03:54 AM |
