diyAudio Sponsor
Old 28th May 2004, 07:44 AM   #1
Default Sansui 1000 outputs?
Am having no luck finding out what impedance and wattage Sansui 1000 (not 1000A) output transformers are. Any info?
Old 28th May 2004, 08:35 AM   #2
Frank Berry's Avatar
As I recall, the amp is rated at 55 w.p.c.
What are the output tubes?
From that information, we should be able to make an educated guess.
Frank
Old 28th May 2004, 10:27 AM   #3
Jax is offline Jax  Sweden
If you know the secondary windings it's easy to find out the primary.
For example: connect 6V AC to the 8 ohm winding. the primary will have high voltage here Measure the voltage over the whole primary. Turns ratio is the primary volts divided with 6V. Primary impedance is approximately 8x(turns ratio squared).
Say you measure 150V over the primary with 6V at the 8 ohm winding. Turns ratio is 25. 8x25x25 = 5000 ohms.
Jan
Old 28th May 2004, 06:18 PM   #4
Talking Sansui outputs
Jan--You just saved me a lot of time. With 6.0 volts on the 8 ohm secondary, I got 120 volts. With your formula, I figured I've got a 50 watt 3200 ohm plate/plate output here, with the legendary Sansui performance (I've used 1000A outputs with 6GM5s and had incredible results). The only question mark now is the maximum plate voltage. The 1000 used 25E5 sweep tubes, which are rated at a max of 250 volts @ 200 max ma. Maybe I should settle on a lower wattage amp using EL86/6CW5 tubes. Thanks much.
noob question about B-1000 sansui ed2000145 Solid State 1 15th May 2009 10:46 PM
Balanced outputs used as inverting & Non-inverting preamplier outputs gni Solid State 4 19th September 2008 03:25 AM
8V on outputs dome406 Chip Amps 3 11th September 2005 03:16 PM
Selling outputs... li_gangyi Swap Meet 0 2nd September 2003 01:56 PM
how low is 'low DC' on SOZ outputs? psarin Pass Labs 8 8th March 2002 01:39 PM
Page generated in 0.07320 seconds (71.42% PHP - 28.58% MySQL) with 10 queries
