Out Of Order - diyAudio
Old 27th May 2004, 06:07 PM   #1
alk is offline alk  Europe
alk's Avatar
Default Out Of Order
hi,
My tube amp was working well until I plugged in a defective guitar booster.
my trafos give me 220v as before but after bridge rectifying i get 680v AC!!!!!
I don't get it, i am just a DIYer not a tech. Can somebody help? I have bought another bridge but i must now what has happened - safety reasons.
Also as i had 400v max. caps and they went up to 600v and more,
should i change them all?
I fear for my OT's.
Old 27th May 2004, 06:11 PM   #2
SY's Avatar
You probably lost your rectifiers and possibly the filter capacitors.
If you're not experienced with high voltage work, DON'T MESS AROUND WITH IT, let a competent tech do the work. Electrocution and explosions are entirely possible.
The good news is that your OPTs are probably OK.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 27th May 2004, 06:18 PM   #3
alk's Avatar
Old 27th May 2004, 10:58 PM   #4
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Default Right out of order
Originally posted by alk
Also as I had 400V max. caps and they went up to 600V and more, should I change them all?
Yes, you should. You have stressed them. They might not blow up immediately, but their lifetime has been drastically shortened. They need to be replaced. Find an experienced person to fix it...
("Right out of order" = "You shouldn't have done that.")
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 27th May 2004, 11:12 PM   #5
alk's Avatar
I've installed a new bridge and still no DC coming out. I get 440v AC in my multimeter. How this can happen? I'm lost, my multimeter works well in other readings. What the hell is going on?
How a 230v trafo can give 440v AC after rectifying is a complete mistery to me.
Old 28th May 2004, 07:50 AM   #6
SHiFTY is offline SHiFTY  New Zealand
SHiFTY's Avatar
You may have fried your multimeter. I killed one with 700VAC once, it gave very strange readings.
Take the amp to a tech.
Old 28th May 2004, 11:57 AM   #7
alk's Avatar
yeah i suspected the multimeter went wrong. I've done some testing to find out it doesn't read DC anymore, now all is AC. Having said that, my problems are not resolved. Now i have 440 v
DC where it should be 280v. Volts readings are ok. It reads my house 230v accurately and i tried with a dc transformer that i got and it reads 12v well but instead of dc gives ac which is what is wrong with my multimeter.
So give the high voltage ? It is a 230v trafo.
Old 28th May 2004, 01:14 PM   #8
alk's Avatar
Proof.
Old 28th May 2004, 07:51 PM   #9
alk's Avatar
Forgot about my multimeter, changed bridge, replaced caps and voilá....sweet music playing
Thanks to all those who helped. Tubes are great.
1st order Passive Line Level Crossover + 2nd order Highpass? alexclaber Multi-Way 11 4th January 2008 07:15 PM
deceptive perception ? 1st order-2nd order question poldus Multi-Way 4 10th April 2007 11:58 PM
My 1st order butterworth filter better than 4th order L-R: Why? philipreji Solid State 61 1st March 2007 04:50 PM
2nd Order Tweeter + 3rd Order Woofer = OK? Jay Multi-Way 3 12th September 2005 12:12 PM
1st order ? L-R 2nd order? or transient perfect?? Ken L Multi-Way 6 17th October 2003 04:22 PM
Copyright ©1999-2017 diyAudio
