| diyAudio Sponsor | ||
#11 |
If a mono FM set is acceptable, a super-regen with a single tuned circuit could form the basis for experimentation. Years ago I built an FM receiver using an autodyne frequency change, resistance coupled IF stages and a pulse counting detector, again with a single tuned circuit, so it was considerably simpler than a standard FM superhet.
Mind you, the FM band was a lot less crowded then... |
#12 |
diyAudio Moderator Emeritus
What ever happened to homodyne receivers?
| What to do with TMC tube radio gear? | diamondsouled | Tubes / Valves | 4 | 31st March 2009 01:30 PM |
| Philips Tube radio | Grifon | Tubes / Valves | 5 | 20th September 2007 03:40 AM |
| Help - tube radio | JDeV | Tubes / Valves | 49 | 19th October 2006 08:18 PM |
| Old russian tube radio | janar74 | Tubes / Valves | 17 | 2nd June 2003 01:52 PM |
| Another tube radio | Magnetmaz | Tubes / Valves | 7 | 11th March 2003 06:01 PM |
| Page generated in 0.07381 seconds (58.56% PHP - 41.44% MySQL) with 11 queries |
