Home Forums Articles Links Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Tubes / Valves All about our sweet vacuum tubes :)
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing
Thread Tools
Old 26th May 2004, 10:34 PM   #11
G is offline G
G's Avatar
Default Re: Great looking Amp...
Originally posted by mourip
Did you make the base yourself?
No. I'm not that good at finish carpentry. I had a cabinetmaker that lives nearby make the frame and one for my planned linestage also. Any competent cabinetmaker should be able to build you a frame with dovetail joints on the corners. The cost was only $20.
Gavin
Old 26th May 2004, 11:59 PM   #12
DrDeville's Avatar
That is indeed "Tea for the Tillerman". Good eyes!!
That album is part of the music that is forever a part of my gestalt.
This amp has more hum than my first humble project does. Go figure huh?
Indeed. I doubt you're discouraged, and you shouldn't be. As you undoubtedly know, there's plenty of things you can do--resolder joints, adjust the wire paths, use coax for the filament wiring, switch to DC filament power, etc. You'll get rid of it.
Thank you very much for the compliments.
You deserve them. Thanks for the photos.
Best,
George Ferguson
Old 27th May 2004, 01:46 AM   #13
G is offline G
G's Avatar
What a novel idea. Hadn't thought of that one. I solved the problem. I found that the 5687 I was using was microphonic. I also biased the filaments approximately 40v above ground. No more problem. You have to put your ear about 4 inches from the speakers to hear any hum or hiss. I can live with that.
Gavin
Old 27th May 2004, 02:03 AM   #14
DrDeville's Avatar
Congrats!
Why does biasing the filaments above ground reduce the hum?
Best,
George Ferguson
Old 27th May 2004, 05:07 AM   #15
G, GREAT WORK!!
The attention to detail of layout is truly a class winner in my strive-but-never-get-there dream of a 'professional' look both underneath and above.
Old 27th May 2004, 01:19 PM   #16
G is offline G
G's Avatar
Congrats!
Best,
George Ferguson
Try this thread. It will explain it better than I can.
http://www.diyaudio.com/forums/showt...p?postid=90211
Gavin
Old 27th May 2004, 05:52 PM   #17
DrDeville's Avatar
Thanks Gavin,
To save others digging:
From Sir Bas Horneman, I gather that electrons emitted from the heater itself can travel to the cathode, causing hum. Raising the heater bias stops this effect.
But perhaps the major advantage is preventing filament-cathode arcing in designs where the cathode can swing high above ground.
Thanks again, and I hope I got that right!
Best,
George Ferguson
Thread Tools
Porn and the Art of Vacuum Tube Fabrication Nordic Everything Else 4 12th September 2008 03:58 PM
BIX porn... Bas Horneman Analogue Source 6 10th July 2005 08:47 AM
to some of you, this will be porn. noisenyc Full Range 56 14th December 2004 10:59 PM
Need someone to host my "TUBE PORN" images. G Tubes / Valves 2 25th May 2004 08:17 PM
Amp Porn MantramAudio Chip Amps 43 18th September 2003 03:47 AM
Page generated in 0.33947206 seconds (56.40% PHP - 43.60% MySQL) with 10 queries
Copyright ©1999-2009 diyAudio
