Old 25th May 2004, 09:15 PM   #11
frugal-phile(tm)
planet10's Avatar
Originally posted by SY
p10- all you need is a Jensen JT11-P1 on the input...
or get the balanced pre out the gate (have a significant portion of the kit already, and the rest is mostly paid for)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 25th May 2004, 10:02 PM   #12
Combination bias attempts to have "EVERYTHING". The unbypassed 100 Ohm cathode resistor provides: some of the grid bias needed, stabilization of the operating point, and reduced distortion due to degeneration. TANSTAFL does apply, as the O/P impedance is raised slightly.
Eli D.
Old 25th May 2004, 10:22 PM   #13
diyAudio Senior Member
fdegrove's Avatar
Why the extra xformer?
You can easily ignore it, the Boyle idea also provides for some extra safety to the output tubes in case the bias supply goes on the blink.
Needless to say...I like it.
Frank
Old 25th May 2004, 10:28 PM   #14
SY's Avatar
Balance and galvanic isolation. Steve Eddy has brainwashed me.
If there's a sucker born every minute, where do the rest of them come from?
Old 27th May 2004, 06:07 AM   #15
cwteoh is offline cwteoh  Malaysia
I am really not very sure about the schematic. From my second schematic, any issue found? should I get started with it? Anyone can tell me how it sounds like?
C.W. Teoh
DIY Dynaco ST70 wingking3000 Tubes / Valves 2 25th July 2008 10:20 PM
Bias adjustment on Dynaco ST70 ghisdal Tubes / Valves 1 12th March 2007 08:05 PM
DIY Preamp for use with Dynaco ST70 liggs17 Tubes / Valves 3 7th December 2006 06:46 PM
Dynaco ST70 clone Tekko Tubes / Valves 8 9th April 2005 02:02 PM
SDS power supply board for Dynaco ST70 Mikelo Swap Meet 0 17th January 2005 09:58 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
