12b4a wiring question
Old 23rd May 2004, 05:39 AM   #1
zobsky is offline zobsky  India
zobsky's Avatar
Default 12b4a wiring question
another doubt from the trenches
1. the 12ba4 datasheet notes that pin 4,5 are heater pins and pin 3 is the heater center tap. do i omit pin 3 or do i use pin 4,5 as a floating heater circuit and ground to Power supply ground (center tap on high voltage power supply)?
2. pins 2,7 are both grid pins. do i tie them together or just use one of them
thanks in advance :
"Not everything that can be counted counts, and not everything that counts can be counted." - Albert Einstein
Old 23rd May 2004, 08:37 AM   #2
dhaen is offline dhaen  Europe
diyAudio Moderator Emeritus
dhaen's Avatar
If you have 6.3v available, then link pins 4 & 5, and connect one side of your 6.3v to that, and the other to pin 9.
If you have 12.6v available, connect one side to pin 4 and the other to pin 5. Ignore pin 9.
Use either pin 2 or pin 7, or both to connect to the grid. Sometimes it's convenient to connect the grid leak resistor to one pin, and the signal in, to the other.
Old 23rd May 2004, 08:39 AM   #3
Jax is offline Jax  Sweden
If you intend to use 6.3V heater voltage, tie 4 and 5 together and feed 6.3V to 3 and the 4-5 joint.
If you use 12.6V, feed 4 and 5, leave 3 floating.
You can use either of the grid pins or tie them together. If you use grid stopper resistor, tie one resistor to each grid pin.
Jan
Old 23rd May 2004, 08:41 AM   #4
dhaen's Avatar
Default Jax'd.... and stoppered...
Snap
Old 23rd May 2004, 08:58 AM   #5
We posted in parallel but I took a couple of minutes with the data sheet
Jan
Old 23rd May 2004, 01:18 PM   #6
zobsky's Avatar
thanks all,
expect a progress report in a few days, .. touchwood
the tweaking of this thing should be interesting
12b4a wiring questionHide this!Advertise here!
DVC Wiring Question 69stingray Multi-Way 3 6th April 2007 12:42 PM
Wiring question LizardBrain Multi-Way 4 26th March 2006 03:46 PM
newbie with input tran. question and wiring question imo Solid State 0 18th January 2006 10:10 PM
sub wiring question trailsnail85 Car Audio 12 20th August 2004 02:54 PM
A wiring question. G Tubes / Valves 4 29th December 2002 01:08 PM
