Amp with 6c33 - diyAudio
Old 22nd May 2004, 01:47 PM   #1
Exclamation Amp with 6c33
Hi (hola), i have found this marvel, an amp whith 6c33, photos and schematic, very well explained (so i believe), i need help with the translation to english or/and spanish(yes,yes, Babylon and the other do it, but the technical stuff is very bad translate) i wish to share with all you, this is the link http://www.jogis-roehrenbude.de/Lese...Doppelamp.htm.
Thanks and enjoy.
Federico.
Old 22nd May 2004, 02:17 PM   #2
diyAudio Senior Member
fdegrove's Avatar
As that site is using frames it's easier to access through:
From the lefthandside pane scroll to Leser-Projekte, click Leser-Briefe, scroll down in the righthandside pane to +/- 3/4 towards the bottom, click Eintakt A Parallel Single End Vertarker mit....und so weiter...to see Klaus Barton PSE 6C33-C amp.
In case you decide to build it, keep in mind that the 5U8-C rectifier has no equivalent and requires a special socket.
If you need help translating from German to English, I may be able to help. just send the snippets you want tanslated by e-mail to me.
Frank
Old 22nd May 2004, 02:46 PM   #3
Thanks, for a moment its very difficult for me, and very hard to find tubes, but keep it in mind , is very beautiful, and sound is so well how its look?. In this page i find a lot of very well explained and detailed amps, but the thing what most impress to me is the cuality of finish of all of them, an teuton quality no doubt.
Thanks.
Federico.
6c33 Se morfeas Tubes / Valves 110 23rd November 2010 07:41 PM
6C33 design comments? nickds1 Tubes / Valves 38 5th February 2007 12:53 PM
6C33 Circlotron pat49hk Tubes / Valves 50 26th January 2006 09:06 AM
6c33 Set Alastair E Tubes / Valves 0 7th May 2005 11:29 PM
Buy 6C33 in Canada, where? Jeffy74 Tubes / Valves 4 16th February 2004 01:39 PM
Copyright ©1999-2017 diyAudio
