Proposed Transfomer/Valve Layout - diyAudio
Old 21st May 2004, 01:34 PM   #1
BL21DE3 is offline BL21DE3  Scotland
BL21DE3's Avatar
Question Proposed Transfomer/Valve Layout
Hi Folks,
This is my first post here having lurked around the forum for a while now. I'm in the process of building a valve phono stage. The circuit/electronics are all sorted, so now plans have shifted to the case. I've attached a schematic of the proposed layout for the valves and transformer, with the valves being numbered in accordance with their position within the circuit (i.e 1 is the first valve etc.). My query is can any of the more experienced DIYer's spot anything inherently wrong with this layout or suggest a more sensible layout? Any advice would be appreciated.
BL21DE3
Old 22nd May 2004, 09:21 PM   #2
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
just go for it.
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 23rd May 2004, 01:46 AM   #3
The physical arrangement makes sense.
Did you allow for DC heating of the 6SL7S?
Eli D.
Old 23rd May 2004, 10:09 PM   #4
BL21DE3's Avatar
Thanks for the positive replies guys .
The 6SL7s are going to be AC heated for the moment, though there is enough room to implement a DC heater circuit.
Old 23rd May 2004, 10:35 PM   #5
diyAudio Senior Member
fdegrove's Avatar
It's not just real estate but you'd need the proper xformer too...
Either way, phonostages and AC heaters don't really wed too well...
Frank
Old 23rd May 2004, 10:44 PM   #6
Either way, phonostages and AC heaters don't real wed too well...
Frank is RIGHT. Energizing heaters with DC in phono stages is MANDATORY.
It's just possible that a RCA circuit built around genuine 7025s or Sovtek 12AX7LPSes would have tolerable residual hum levels. Without the spiral wound hum bucking heater, there isn't a ghost of a chance.
Eli D.
Swap Shanling CD-T80 valve CD player for Quad valve equiment johnm Swap Meet 2 24th September 2009 12:15 PM
What to do with a 5k output transfomer? Switch Tubes / Valves 17 23rd July 2008 08:12 PM
any pcb layout for marshall standard 50w valve amp ? Ahmad_tbp Instruments and Amps 2 16th February 2006 07:04 AM
Input transfomer on P3A jesper Solid State 9 30th October 2004 07:39 PM
Think this is worth $60? (transfomer) Hybrid fourdoor Swap Meet 5 22nd June 2004 10:56 AM
Copyright 1999-2017 diyAudio
