diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   EL84 or 6v6 or something else? (http://www.diyaudio.com/forums/tubes-valves/34391-el84-6v6-else.html)
svokke 20th May 2004 08:41 AM
This will be my first hifi tube project, I have a lot of experience building guitar amps and repairing tube stuff.
I've got two hammond 125E transformers and two power transformers (230V/120mA, 6.3V 4A). The hammond is rated at 15W and has many primary impedances: 1k2 to 20K.
Now I'm planning to build two monoblocks for use wit my B&W DM4. These are bookshelf speakers with a sensitivity of "4.8 watts into nominal impedance (i.e 6.2 volts) for a sound pressure of 95dB
pink noise at 1 metre". Power handling is 25W
The DM4 are used with a subwoofer, so frequency response below 80Hz is not so inportant.
I still have to choose some tubes. I want to use a 6SN7 in the preamp, but can't decide what to get for the power amp. It should be a tube with a good availability like EL84(6bq5), 6V6, SV83, ECL82 (6BM8),...
How can I choose between these?
Fuling 20th May 2004 09:02 AM
Donīt forget 6AQ5, aka EL90.
I have good experience of these and at least here in Sweden they are (very) cheap and easy to find.
They are electrically almost identical to 6V6, only a little bit weaker.
G 20th May 2004 02:43 PM
I would go for a SE EL34 with a 6SN7 driver. Go all octal. That is going to be my next project. After I finish the one I'm working on now of course.:rolleyes: :rolleyes:
Gavin
zobsky 20th May 2004 03:11 PM
Re: EL84 or 6v6 or something else?
amongst your mentioned choices, .a 6sn7-6v6 or 6sn7-el34 stand recommended
the el34 will have more power but the midrange of the 6v6 is something special
Fuling 20th May 2004 04:06 PM
SE EL34
The Hammond 125E isnīt suitable for SE use.
You guys are probably thinking about 125ESE transformers, which is a different animal.
G 21st May 2004 08:35 AM
You could build a nice little push pull, triode strapped, 6v6 amp and get very nice sound at moderate levels if you bias them to run hot ( 90% of rated current ). At low signal levels the amp will be working in the "class A" region and you will hear the glory of class A triodes doing their thing. here is a link to a PP 6BQ5 PP amp that was originally designed my Magnavox engineers ,when magnavox was known for solid design and solid performance, and tweaked into a excellent design by Gabe V, one of the regulars on this forum.
http://members.tripod.com/~gabevee/pptube.html
Resources saved on this page: MySQL 18.75%
