shared parts between channels
Old 13th May 2004, 11:34 PM   #11
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Default MR. BLUMLEIN WHERE ARE YOU NOW?
The Decca....I had one of those rattlesnakes myself....
I can't remember what the channel separation was on those three pinners...if any.
MEMORY LANE...
P.S. Those Quads were the IIs, I assume? Could have kept me guessing for an integrated amp for ages....
Frank
Old 13th May 2004, 11:45 PM   #12
On Hiatus
SY's Avatar
No need for Quad IIs, the integrated was... integrated. ESLs, my lad, ESLs.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 14th May 2004, 12:01 AM   #13
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Default Re: More envelope backs
At the magic 100 Hz, this cap will run about 1.5 ohm in impedance (the ESRs are in the milliohm range so can be neglected).
The typical, rather nasty, capacitors that are used in an amplifier that cost-cuts in this way have significant ESR. I've just found a 100u 6V3 (which would be typical) having an ESR of 3.45 Ohm. (Rubycon MS5 series.) Assume gm of 2mA/V, giving rk of 500 Ohm, and we have crosstalk across the band at -43dB just for one stage.
By the way, FFSS (applied to Decca cartridges) stands for Fatally Flawed, Sometimes Superb. I had Deccas too... Excellent mono cartridges (if you got a good one), but stereo was a signal too far.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 14th May 2004, 12:07 AM   #14
fdegrove's Avatar
You sure have me puzzled there...
FFSS
Lemme guess....Full Frequency Stereo System?
I suppose they didn't have a dictionary on stereo systems in those days either...he,he...
Wouldn't even track a railroad....
Frank
Old 14th May 2004, 12:14 AM   #15
EC8010's Avatar
Not quite; Full Frequency Stereo Sound.
Deccas could track, just not vertical stuff. And they needed a really robust arm. I designed my first "proper" arm with the Decca Gold in mind. It was an oil-damped unipivot and it worked, but end-of-side distortion was still a problem, and the vibration loosened the screws securing the platter bearing on my Garrard 301. The whole thing needed to be tightened every three months!
This is wandering way off topic - it's just as well no moderators are watching.
Old 14th May 2004, 03:20 AM   #16
jlsem is offline jlsem  United States
jlsem's Avatar
What is the disadvantages of this (crosstalk?)
What is so terrible about crosstalk? It occurs to me that it is much easier to measure than to hear.
John
Old 14th May 2004, 04:20 AM   #17
On Hiatus
SY's Avatar
John
This is true of most phenomena in audio. For ultimate performance, you want the cross-talk as low as possible. For audibly "blameless" amplification, you can tolerate quite a bit before it becomes audible.
EC: Just for grins, I measured the impedance of a 1000u/35V cap I happened to have laying around here. US$0.59 from Mouser, if memory serves. About 1 x 2 cm. Under 100 milliohms total impedance at 10kHz. Admittedly, I haven't measured it in a warmer environment yet, but...
Old 21st May 2004, 08:48 AM   #18
G is offline G  United States
G's Avatar
Default Re: shared parts between channels
Originally posted by metebalci
Is it a common practice to share components in cathode bias circuits in integrated amplifiers ? What is the disadvantages of this (crosstalk?) ? Does it have an effect on stereo seperation ? Is it another main difference between monoblock (or dual-mono) and integrated amplifiers ? (the other difference is using seperate supplies for each channel)
MB
Steve Deckert of ZEN Triode Amp fame uses one cathode resistor and bypass capacitor shared between the channels of his SE amps. I tried it when I built my psuedo-Zen and I never changed back. It improved the imaging in my system. YMMV.
Gavin
Old 21st May 2004, 04:16 PM   #19
fdegrove's Avatar
On this preamp I have there's this funny switch labeled MONO...
I wonder what the heck it's for though???
Sorry G, this resistor couldn't...well, resist.
Frank
shared parts between channelsHide this!Advertise here!
Connectors for shared power transformer 454Casull Power Supplies 0 20th April 2009 11:23 PM
SE With shared Rk in output mashaffer Tubes / Valves 18 13th October 2008 10:10 PM
T-Amp and Pre Amp shared power problem tedlevit Class D 3 26th February 2008 02:22 PM
Dual Mono PSU with shared earth.. Bas Horneman Tubes / Valves 28 27th April 2005 01:16 PM
shared power supplys for buffer and chip amp pete.a Chip Amps 1 4th September 2004 04:24 PM
Copyright ©1999-2017 diyAudio
