First amp build questions
Old 13th May 2004, 01:23 PM   #1
edsmith is offline edsmith  Australia
Question First amp build questions
im building a slightly modded marshall 1987 plexi for my first builld. I really like plexi amps but i really like that smooth tone from old fender amps also. I noticed the Fender 'Super Amp' 5E4-A schematic is very similar to the 1987, but they have different tubes.
super amp has:
2 12AY7s
1 12AX7s
and for the power tubes
2 6V6
while the marshall has 3 12AX7s and the 2 EL34s.
super amp schem:
http://www1.korksoft.com/~schem/fend...5e4a_schem.pdf
plexi schem:
http://www1.korksoft.com/~schem/mars...1987_plexi.pdf
Would I be able to take the plexi tubes out and whack in the super amps ones without something bad happening?
thanks guys,
ed
Old 13th May 2004, 05:31 PM   #2
Sch3mat1c is offline Sch3mat1c  United States
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Without looking at the schematics, I can tell you you'll have to rebias and rewire the sockets to use EL34s in place of 6V6s. Since you're doing a new build you could just chop the EL34 output circuit and paste it onto the driver circuit you want. Although being a guitar amp I wouldn't be suprised if you could get away with it anyway, making sure all the grids are connected that is.
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Old 13th May 2004, 08:06 PM   #3
drembo is offline drembo  United States
Default plexi vs tweed super
The plexi with 6V6 output tubes is still going to sound pretty much like the plexi. The plexi has much more gain coming out of the preamp, the tone controls are completely different, and I think the plate voltages on the output tubes of the plexi circuit are going to exceed the maximum values for a 6V6 tube.
First amp build questionsHide this!Advertise here!
Solo206 build questions yan6 Full Range 1 22nd December 2008 10:38 PM
Fonken Build Questions cgrums Full Range 3 17th October 2008 01:54 PM
first amp build... wiring questions jdbrocious Tubes / Valves 43 4th March 2008 04:21 PM
UcD 700 Amp Build Questions PrecisionAudio Class D 0 14th December 2005 07:50 PM
questions on first sub build aeronautica86 Subwoofers 5 17th September 2005 12:29 AM
Copyright ©1999-2017 diyAudio
