Help needed changing from srpp5814a to srpp12bh7a
Old 13th May 2004, 11:19 AM   #1
georgehifi is offline georgehifi  Australia
georgehifi's Avatar
Send a message via MSN to georgehifi
Default Help needed changing from srpp5814a to srpp12bh7a
I need help to change the cathode resistors to the correct value, at the moment it`s set up for a 5814a srpp driving a 300b. Top section of the srpp plate is 310v naturally this get halved to 155v each section and cathode resitors on both sections are 4.3k I tried a 12bh7a in place of the 5814a and got a nice improvment, but i know it`s not working at it`s optional point, can anyone work out what to change the two cathode resistors to to give the 12bh7a it`s best operating point, someone suggested that i drop both of them to 3.3k Can anyone confirm this.
The circuit is 5963 straped (input tube.)
5814a srpp (pre driver)
300b (driver)
interstage transformer
805 (output tube)
Thanks George
Frank your the srpp king, what do you think?
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 13th May 2004, 11:46 AM   #2
Burnedfingers is offline Burnedfingers  United States
George
Would you post the schematic for all to see?
Joe
Old 13th May 2004, 01:56 PM   #3
georgehifi's Avatar
Joe i`ve emailed the circuit to you aol address in your profile, i have no idea how to post a circuit diagram, hope you can do it for me.
Cheers George
Old 13th May 2004, 11:56 PM   #4
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
George,
As I think Joe's pretty busy...If you mail me the circuit I'll try to post it here for you.
Frank
Old 14th May 2004, 01:26 AM   #5
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
George,
What did you do the scematic in -- the picture embedded in the word doc was just a ghostly shawdow (put almost anything in Word and it gets pooched).
Here is a forum size pic thou... (print pdf out from word, RIP it in Photoshop, grag the top slider in the gamma almost to the bottom one and we get asomething that is at least representative.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 14th May 2004, 02:24 AM   #6
georgehifi's Avatar
Thanks Dave, wish you could show a dumb ---- like me how to do that, btw i do`nt run any feedback on mine now, and my b+`s are a little different also, this amp guys has a killer sound, way beyond any expectations i had for it. And even with no feedback i`m still only 1db down at 20k. i`ve got the 12bh7a (tungsol black plate ) in at the moment, it`s a good sounding tube in this srpp stage, you were right Frank 12bh7`s are great, it not running at it`s best yet, over at AA Damir said i`ve probally got around 1.7ma of bais current on it, and that`s maybe to low to kick it up to 4.4ma change the 4.7k cathode resistors to 1.5k can you guys confirm this.
Thanks George
Old 14th May 2004, 03:10 AM   #7
George
For some unknown reason I haven't gotten any mail from you. I see it is posted now for viewing.
Joe
Old 14th May 2004, 11:51 AM   #8
fdegrove's Avatar
For a B+ of around 310 V I came up with 1K2 bias resistors.
So for a higher B+ as you're having 1K5 should do just fine.
It should also finally wake up that 300B driver tube...
Let us know what you think of it,
Frank
Old 20th May 2004, 01:33 AM   #9
georgehifi's Avatar
Yeah Frank, reporting back very nice, the 12bh7a (Tung-sol blackplate) is now at 300vat the top plate of the srpp which halves to 150v for each section, i now have 1.2k cathode resitors, which now have a voltage drop across them of 5.4v each which i equate to 4.5ma plate dissapation for each section being .675watt each section, do you concure.
One more question Frank do you think i have enough voltage swing on the 12bh7a for the 300b.
Also the input i`m using a rca 5963 blackplate it has about the same plate volts and current draw per section as the 12bh7.
Cheers George
Old 20th May 2004, 02:02 AM   #10
fdegrove's Avatar
How did this happen? Did you change something else in the PS?
Yes but the more B+ you have the more it can swing voltage, in theory at least.
There's of course a point where it'll start to distort the output.
According to the Chen diagram it has even more B+ voltage than the SRPP stage, unless something got scrambled I don't understand how that can be.
I don't understand either why he felt he needed to put both sections in //.
I'm pretty beat but didn't you calculate what the resistors are dissipating iso the plates?
Frank
Help needed changing from srpp5814a to srpp12bh7aHide this!Advertise here!
Changing bridge. Advise needed Fidelity Audio Power Supplies 10 7th December 2010 12:11 PM
Changing 1543 DAC from 8V to 5V. Help needed Nielsio Digital Source 5 1st January 2009 10:01 AM
Schematics 4 changing 8412 with 8416 needed jondoe Digital Source 5 23rd December 2004 08:43 PM
Changing ZEN to Ret. of ZEN boq Pass Labs 1 28th May 2004 11:30 AM
Changing BF's for MJE's Bensen Solid State 2 27th May 2003 06:39 AM
Copyright ©1999-2017 diyAudio
