B+ Voltage - diyAudio
Old 11th May 2004, 12:34 PM   #1
s2kov is offline s2kov  Canada
s2kov's Avatar
Default B+ Voltage
I was building the power supply using the 5AR4 rectifier tube. Using Duncan's PSU2 software, i was expecting a B+ of 300V using below configuration:
232V - 0 - 232V => 22uF => 5H => 47uF
Actual reading on DMM was measured at 329V.
Is the B+ voltage right? It supposed to be lower than that since there is a voltage drop on each plate of rectifier tube.
Appreciate your help....
Old 11th May 2004, 12:46 PM   #2
Frank Berry's Avatar
Did you put a load on the power supply?
Frank
Old 11th May 2004, 01:02 PM   #3
s2kov's Avatar
Not yet.
Old 11th May 2004, 01:33 PM   #4
When you put a load on the supply, the voltage will fall.
Frank
Old 11th May 2004, 01:46 PM   #5
diyAudio Senior Member
fdegrove's Avatar
Having a 329VDC result under no load conditions is only 10% off, not bad in my book.
As our other Frank suggests the voltage will drop with a load attached.
Testing PSUs with no load attached isn't good practice and can be dangerous.
If later on you find to voltage to be off target you can always fiddle a little with the value of the first cap behind the rectifier or try a choke input filter.
Frank
Old 11th May 2004, 02:13 PM   #6
s2kov's Avatar
Will the voltage drop in the rectifier tube will happen during with load condition?
QUOTE]Originally posted by fdegrove
[/QUOTE]
Oopppsss Thanks for letting me know of this....
Old 11th May 2004, 04:16 PM   #7
JojoD818's Avatar
I see we have 2 Franks here. Pleasant day to both of you.
Kabayan!
Good thing your caps voltage rating wasn't exceeded when you tested your psu without load.
As always, safety first!
Goodluck,
JojoD
Old 12th May 2004, 04:19 AM   #8
s2kov's Avatar
JojoD,
Thanks for the reminder. Actually, caps voltage rating was based on VAC * 0.707 calculation but still there are rules that needs to be considered.
Regards.
Andy
Kabayan!
Goodluck,
JojoD
Old 13th May 2004, 02:31 AM   #9
arnoldc is offline arnoldc  Philippines
Send a message via Yahoo to arnoldc
wow! good thing you were not building a PSU with 420 B+ and 450V caps! without a load, it will....
Old 13th May 2004, 02:31 PM   #10
JojoD818's Avatar
That's why I always say to myself. SAFETY FIRST!
845 Low voltage SE AMP =maximum= Tubes / Valves 16 20th January 2013 03:31 AM
Should I use high voltage value zeners or multiple lower voltage zeners in series? jarthel Parts 7 30th May 2006 05:56 PM
Rail Voltage to Capacitor Voltage Mermprin Parts 6 20th September 2004 04:56 PM
secondary voltage vs. primary voltage Stocker Parts 5 11th March 2004 08:41 PM
Rail voltage compared to transformer voltage SteveG Solid State 4 23rd July 2002 12:50 AM
Copyright 1999-2017 diyAudio
