CCS Conceptual Qs, Using Gary Pimm CCS as Example
Old 12th May 2004, 03:41 PM   #21
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Originally posted by SY
One technique sometimes used to get around the CS limitations is to direct couple to a cathode follower, then take the signal from there (a low impedance source).
That can be quite a useful technique if you're a bit short on HT voltage. A cascode using PNP transistors makes a decent anode load, and for a given HT voltage has far more compliance than the equivalent (valve) section of a mu-follower. The DC coupled cathode follower after it only need a simple CCS.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
CCS Conceptual Qs, Using Gary Pimm CCS as ExampleHide this!Advertise here!
is Gary Pimm still around? Nanook Tubes / Valves 9 17th June 2007 10:15 PM
Gary Pimm's MOSFET CCS Fanuc Solid State 4 31st March 2007 11:46 PM
Gary Pimm's site down? Ryssen Tubes / Valves 6 1st March 2007 10:36 PM
Gary Pimm website? SunRa Tubes / Valves 8 29th January 2007 07:06 PM
Gary Pimm Jaime Tubes / Valves 0 25th January 2007 12:03 AM
