diyAudio Sponsor
Old 8th May 2004, 10:36 AM   #1
alk is offline alk  Europe
alk's Avatar
Default Hammond SE Transformer question
I have just build my first tube amp and i was designing a nice rosewood box for it when i found my output transformer was just too big for this little amp- my mistake. I wanted to do a little and cute box.... The trafo is a hammond 125ESE. I have seen the smallest of the SE line rating 3W really cheap (Hammond ASE) and as my amp puts out 2w am thinking of buying it and use the ESE(15w) for a guitar amp(the amp i made is too clean for electric guitar).
My question is this: will i miss something in the sound?
I am happy with its sound but i plan to make another amp with some Russian valves i saw in the future. Will i repent if i replace the transformer? If somebody tells me the sound would change for worse i would not do it.
I'm not an audiophile but my ears are not fooled easily.
Old 8th May 2004, 11:02 AM   #2
baggystevo82's Avatar
Send a message via MSN to baggystevo82
So long as the primary resistance and the secondary taps are correct it should be fine. I think as far as transformers go, all other things being equal, the smaller they are the better the frequency response will be, though I dont know if this will be noticable. If it's rated 3W, has the right primary resistance and the right secondary taps, and is cheap, Id go for it. If you decide you dont like it you can always swap it back as you say you can get them cheap
I'm a beginner myself so dont take any of this as fact!! I'd wait to see what everyone else has to say on it...
Good luck,
Steve
Old 8th May 2004, 01:56 PM   #3
alk's Avatar
Thanks Steve ...it is also my opinion but i'm also a beginner. People seem to relate big sound to big iron...i dunno
Old 8th May 2004, 02:02 PM   #4
diyAudio Senior Member
fdegrove's Avatar
At what end of the spectrum?
There's alot more than physical size to a good OPT but you just can't get any decent low frequency response out of a miniature sized one...
Frank
Old 8th May 2004, 02:04 PM   #5
Big sound needs big iron due to high power, or the transformer would get too hot. In the case of single ended amps they also have to cope with higher DC flow on the primaries. Your amp is 2W and using a huge opt won't change that.
Just googled for that transformer and apparently the 125ESE can cope with 80mA DC on its primaries and is more suited to single ended KT88 kind of power, which seems a little overkill. I think you should go with the ASE
Steve
Old 8th May 2004, 02:08 PM   #6
I was on about losing top end with really big opt. Im just quoting out of Morgan Jones's book here, I haven't any actual experience apart from the amp I just built. I remember seeing on the sowter site some frequency response curves for their opt, maybe hammond do the same?
Steve
Old 8th May 2004, 02:17 PM   #7
Hmmmm, it says on the hammond site that none of the 125 series are for hifi use
Steve
Old 8th May 2004, 02:56 PM   #8
alk's Avatar
Hi Steve, here they don't think so.
http://members.myactv.net/~je2a3/125ESE.htm
Old 8th May 2004, 03:01 PM   #9
Well theyre cheap anyway so you may as well try em...
According to hammond their response is 100Hz to 15KHz @-1dB and their hifi series is rated 20Hz to 20KHz @-1dB, dunno if you would hear a difference though.
Steve
Old 8th May 2004, 03:06 PM   #10
Hi again,
I just read through a bit more of that link. I think they went for that one as you can configure it for lots of different primary resistances. It is a bit of a worry that two transformers acted so differently though Maybe if you bought more than you need (if they are really really cheap) and picked out the good ones?
Steve
Hammond 269 EX transformer (never used) zenmh Swap Meet 7 4th August 2009 07:06 PM
Question about Allied & Hammond Power Transformer Ratings Bitrex Tubes / Valves 2 6th March 2009 07:31 AM
One Question for Hammond 1620 output transformer Menator Tubes / Valves 1 19th March 2007 10:51 PM
WTB: Hammond 269EX Transformer mrdon Swap Meet 0 12th April 2006 03:05 AM
Hammond Transformer in Toronto drcy Tubes / Valves 0 1st June 2004 02:18 AM
Page generated in 0.29116 seconds (32.56% PHP - 67.44% MySQL) with 11 queries
