help with restoring amp
Old 8th May 2004, 03:35 AM   #11
Eli Duttman is offline Eli Duttman  United States
whats sand and selenium??
Sand is tubehead talk for SS (Silicon).
Before Germanium and, later, Silicon based semiconductors came on stream, semiconductor rectifiers based on the metalloid Selenium were available. Selenium is in the same column of the Periodic Table as Oxygen and Sulfur. Selenium rectifiers look like a stack of square fins. Selenium rectifiers are accidents waiting to happen and MUST be replaced QUICKLY. It is only a question of when, not if, a Selenium rectifier will fail. When Selenium rectifiers fail, toxic vapor and dust is emitted. Other parts may be damaged too. You will probably have to allow for the smaller forward voltage drop modern Silicon diodes exhibit. The UF4007 is a good choice for fabricating Selenium rectifier replacements.
Eli D.
help with restoring ampHide this!Advertise here!
Restoring B&W 2200 cliffforrest Multi-Way 23 9th June 2010 09:35 PM
Restoring old suspension rjb Multi-Way 1 23rd June 2008 03:54 AM
Upgrades and Restoring Bigred Solid State 15 21st August 2007 01:55 AM
Restoring Veneer richie00boy Everything Else 30 26th March 2007 02:38 PM
restoring a marantz 7c pchoi122 Tubes / Valves 3 23rd December 2005 12:30 AM
