diyAudio Sponsor
Old 6th May 2004, 10:54 PM   #1
r!sc! is offline r!sc!  Serbia
Account Disabled
Default Tube preamplifier with PCC88
I need simple preamp circuit with PCC88 tube. Anyone?
And the power supply for that circuit will be great
Thanks.
Boban
Old 6th May 2004, 11:53 PM   #2
DougL is offline DougL  United States
Grab a copy of Dunans Amp Tools TDSL Personal addition. Its Free.
If you do that, you will discover that the PCC88 is a 6DJ8 with a 7 Volt filiment.
There are many 6DJ8 (also called 6922 ) Schematics to choose from.
HTH
Doug
Old 7th May 2004, 12:21 PM   #3
also called ECC88
Federico
Old 7th May 2004, 12:32 PM   #4
jamesjung21's Avatar
& 6N1P (Russian Equivalent)
Old 7th May 2004, 04:58 PM   #5
Account Disabled
Big thanks. Can u suggest me any circuit?
Boban
Old 7th May 2004, 06:03 PM   #6
frugal-phile(tm)
planet10's Avatar
Well not quite... but still a good tube and can be used in similar circuits.
The russian equivalent is 6H23pi (aka 6N23P) which are also labeled 6922 at the factory.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 7th May 2004, 06:37 PM   #7
You can find some circuits at this sites.
http://www.glass-ware.com/tubecircuits/
Or maybe something along the lines of Morgan Jones headphone amplifier (probably pretty good as a pre-amp to)
http://headwize2.powerpill.org/proje...=cmoy5_prj.htm
Old 7th May 2004, 06:41 PM   #8
aparatusonitus's Avatar
Not exactly simple circuits found here, but it's a start...
http://www.vacuumstate.com/schematics.htm
Old 7th May 2004, 07:12 PM   #9
Account Disabled
I found this circuit with PCC88. Opinion, please
Old 7th May 2004, 07:20 PM   #10
IMO, the biggest problem with the 6922, et al in line stage service is its "high" mu of 33. A simple common cathode block has too much gain.
What sort of a source is the line stage going to be used with? If it's a CDP, no gain at all is needed and a tricked out cathode follower buffering the level control will be just fine.
Eli D.
finished my PCC88 preamp Roemhild Tubes / Valves 12 18th January 2012 08:04 AM
My first tube preamplifier:) whee Tubes / Valves 4 29th September 2006 01:26 PM
Pcc88 leo529 Tubes / Valves 17 22nd June 2006 04:06 AM
ECC88 and PCC88 filament voltages sith Tubes / Valves 5 1st April 2004 09:30 PM
Tube preamplifier gchrist Tubes / Valves 9 11th March 2004 03:06 PM
Page generated in 0.08733 seconds (83.90% PHP - 16.10% MySQL) with 11 queries
