diyAudio Sponsor
Old 7th September 2004, 06:15 AM   #31
r!sc! is offline r!sc!  Serbia
Account Disabled
... second
Old 7th September 2004, 02:04 PM   #32
Bernt is offline Bernt  Sweden
Yeah, that would work. The heater voltage is wrong for PCC88 though, changing the value of the 240 ohm resistor to 270 ohm should solve that.
Old 9th September 2004, 01:40 PM   #33
Account Disabled
I found another circuit with ECC88. Is it good
Old 9th September 2004, 02:13 PM   #34
diyAudio Senior Member
fdegrove's Avatar
It would be fine: it is indeed a mu-follower meaning that Ao is close to the amplifiaction factor (mu) of the single triode.
If you look closely you'll notice a feedback loop from the output of that stage to the input grid to reduce gain, distortion (which should be very low already) and output impedance (ditto).
Moreover, there's also a voltage divider with a 1/1 ratio at the input formed by the 100K pot and the 100K series resistor in oder to cut the level of the input signal in half.
All in all much added complexity where you, strictly spoken, don't need it.
Frank
Old 11th September 2004, 02:56 AM   #35
rickl is offline rickl  United States
If I wanted to learn to make a preamp, I'd look at this schematic:
http://www.triodedick.com/6072_voorversterker.html
You will need to change the heater voltage but that is pretty easy.
rick
Old 28th January 2012, 02:03 PM   #36
formula 22's Avatar
Originally Posted by Shoog View Post
I built a cascode line preamp using the PCC88. Unity gain. I based it on Joe Rasmussen's Ultra Linear Gainclone valve buffer (the full tube CCS and MosFet CV implementation). It was a matter of trial and error to get it working so I would have difficulty drawing up an accurate schematic. Still sounds excellent. The PCC88 which I used was a Miniwatt and it bettered both the Mullard ECC88 and the Sovteck 6922.
Using this tube in this configeration requires a flatline power supply as "any" noise bleeds into the signal, the power supply was more complicated than the actual buffer.
Shoog
Hi Shoog!
Please your display schematic.
Thank you
Old 28th January 2012, 02:14 PM   #37
Shoog's Avatar
Originally Posted by formula 22 View Post
Hi Shoog!
Thank you
This is the schematic
The thread about it is;
My version of the Vacuum State FVP5
I would replace the second stage LED with a resistor (whatever sets current to 10mA) as the LED defeats the object of the bottom triode - we learn by our mistakes. Iw ould also probably replace the R4 with a 100K or even 150K.
Shoog
finished my PCC88 preamp Roemhild Tubes / Valves 12 18th January 2012 08:04 AM
My first tube preamplifier:) whee Tubes / Valves 4 29th September 2006 01:26 PM
Pcc88 leo529 Tubes / Valves 17 22nd June 2006 04:06 AM
ECC88 and PCC88 filament voltages sith Tubes / Valves 5 1st April 2004 09:30 PM
Tube preamplifier gchrist Tubes / Valves 9 11th March 2004 03:06 PM
Page generated in 0.09095 seconds (75.64% PHP - 24.36% MySQL) with 11 queries
