PTP wiring
PTP wiring
Old 1st May 2004, 09:18 PM   #1
svokke is offline svokke  Belgium
Default PTP wiring
I was going to mod/rebuild an ugly sounding guitar amp. I opened it up and I was a bit surprised bij the view of the insides. No terminal strips, PCB, eylet board or turret board. Just all the components soldered against eachother very tightly. Not really mod-friendly.
Is this kind of point-to-point wiring worth the extra effort of modding. Or is it better to use some board that I have laying around.
In illusion comfort lies
Old 1st May 2004, 09:21 PM   #2
And here is a view of the whole amp. Note the mounting of the capacitors on the left. Three 470F/450V capacitors mounted to the chassis wit cable ties. I'll mount the capacitors with proper clamps on an ALU L-profile
Old 1st May 2004, 10:27 PM   #3
Eli Duttman is offline Eli Duttman  United States
That's UGLY! Based on what your photos show, I don't think you should waste either your time or your money on that amp. The quality of the "iron" in it rates to be as POOR as the construction.
Turning dung into Gold is just not possible.
Eli D.
Old 1st May 2004, 11:31 PM   #4
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
If it doesn't sound good it can be due to a number of things but I doubt the P2P wiring is the main culprit no matter how sloppy it looks.
Maybe the tubes are biased wrong or maybe the amp never was any good to start with.
Either way it's hard to tell without an o-scope.
Frank
Old 2nd May 2004, 05:58 PM   #5
I also doubt the bad sound is due the PTP job. I traced the schematic and there you can see what went wrong.
The main problem is that there is almost no midrange in both channels.
Also the fact that there is too much bass early in the high-gain channel preamp makes the distortion rough.
So this looks like a nice chassis for a DIY amp. I can even reuse the transformers. The power transformer is very big and doesn't get warm, the output transformer is "standard" quality for a guitar amp. "Undersized" or "flimsy" this is called in the hifi community
Old 2nd May 2004, 06:52 PM   #6
Frank Berry is offline Frank Berry  United States
Frank Berry's Avatar
"If it doesn't sound good it can be due to a number of things but I doubt the P2P wiring is the main culprit no matter how sloppy it looks.
Either way it's hard to tell without an o-scope."
fdegrove is absolutely correct.
IMHO, what you have is a very poorly designed and very poorly constructed amplifier.
I've seen many sloppy looking amplifiers ... some of them sounded heavenly.
Frank
PTP wiringHide this!Advertise here!
Wiring HT2 MTM ZoZat Multi-Way 4 15th May 2009 10:17 PM
Focusing on wiring cable for gainclone!!!Share ur experience in wiring cable.... thomgun_lc Chip Amps 38 31st August 2005 03:46 PM
I'm wiring my 4 channel 8 parallel LM4780 boards... check my wiring :) Audiophilenoob Chip Amps 9 16th August 2005 05:37 AM
Copyright ©1999-2017 diyAudio
