Old 30th April 2004, 03:59 PM   #1
Question How do I measure OPT impedance?
I've got a pair of telefunken OPTs. They are marked:
P=10,000Gktc
s1=4
s2=8
My first problem is that I don't know what leads are 4 and 8 ohm. Secondly, the input side has 3 leads, so I'm wondering if "Gktc" somehow means "center tapped" in german, which would be great, because I'd rather use the 5k primary if there is one....
Any help is appreciated. Thanks.
-Jared
Old 30th April 2004, 07:28 PM   #2
speaker is offline speaker  United States
speaker's Avatar
Some Telefunkens used a common, 4-5 ohm, and a negative feedback tap on the secondary side. Output from the feedback usually went to the front-end. You do not have 4 & 8 ohms hook-ups.
Your unknown tap on the primary side maybe a humbucker tap. Some Telefunkens ran all B+ through the output transformers and then stripped it off, out-of-phase and sent to main supply filtering for the rest of the radio. It was out-of-phase to reduce hum because the radio was SE.
Do you know what model they came out of?
speaker
Speaker Workshop - using "Measure -> Passive Components" to measure ESR ? percy Multi-Way 0 12th March 2006 09:18 PM
How To Measure Input Impedance Of Solid State Amplifier? kelticwizard Solid State 11 28th January 2006 03:34 PM
How to measure the output impedance of the DAC chip ergo Solid State 2 9th June 2004 07:07 AM
Speaker impedance measure by a newbie jormartr Multi-Way 1 17th October 2003 02:09 PM
How do I calculate (or measure) my amp's output impedance? Saurav Tubes / Valves 22 27th September 2003 03:55 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
