| diyAudio Sponsor | ||
Dear members
here the Schematic of VT 100 http://www.drtube.com/audioamp.htm#AR and the Bias adjustment of VT 100 http://mycollins.net/audio/artube1.html Best regards Alex |
#2 |
Hello,
this link is dead http://mycollins.net/audio/artube1.html have you more informations ? Do you know the OUTPUT TRANSFORMER specifications ? Thanks Pascal. |
#3 |
Hi Alex.
Don't suppose you have the VT100 power supply section schematic? Regards Henry |
#4 |
Hi again, found it now so no need, thanks.
#5 |
#6 |
Great link, thanks Alex.
This amp has a problem in the 320v regulator. Started with a big bang and puff of smoke. The 4A power fuse blew, and the 10R 0V to ground resistor blew. Now it runs but puts 420 onto the 320V rail. |
#7 |
Looking at the pictures of the MKIII versus the MKII, the MKIII has got significantly smaller OTs and a smaller power xfmr. It's lost half the input/driver tubes and no heatsinks are visible for the CCS's anymore. Cost cutting with a much higher price?
Ohms Law V = I R Last edited by smoking-amp; 31st August 2011 at 02:38 PM. |
#8 |
It could be a problem of perspective, the pictures are from different distances, I suspect the transformers are the same.
Back to the fault. In this amp (a Mk 2) the resistor R50 has been replaced by a 3 legged fuse (a transistor of unknown type- numbers removed and replaced by paint colour code) and a couple of resistors. The fuse went short so forcing the 320 rail up to 420! So an imperceptable performance 'improvement' compromised the reliability and could have caused some serious damage, when will they ever learn...... |
#9 |
It's one of the reasons I stopped working on ARC amps - lots of complexity and owners who modded the amp or put poor quality KT88s in the amplifier resulting in a lot of collateral damage.. Not easy to get the parts out of their very thick PCBs either..
www.kta-hifi.net |
| schematic for Audio Research SP11? | sean | Tubes / Valves | 10 | 12th January 2011 02:58 PM |
| Audio Research D125 Schematic? | thermionic | Tubes / Valves | 1 | 16th May 2009 03:41 PM |
| Service Manual / Schematic for Audio Research LS3 | teocc_1308 | Solid State | 1 | 9th March 2006 02:39 AM |
| schematic for audio research classic 120 amps? | audiomatic | Tubes / Valves | 5 | 3rd May 2004 04:25 PM |
| I need the Schematic of Audio Research ph3 | purer | Tubes / Valves | 12 | 20th February 2003 06:58 AM |
| Page generated in 0.12201 seconds (80.69% PHP - 19.31% MySQL) with 10 queries |
