Will this work? "Mixed" 300B PPP IT
Old 24th April 2004, 03:08 PM   #1
ppereira is offline ppereira
Default Will this work? "Mixed" 300B PPP IT
Will this work? the driver tubes are either ECC99 or 6C45's.... Phase splitter is a Sowter 8920 Transformer. Each phase of the driver stage is IT coupled to two paralleled 300B output tubes via a Lundahl 1660 transformer in SE to SE configuration.
Thanks,
Old 24th April 2004, 03:45 PM   #2
Fuling is offline Fuling  Sweden
I canīt see any reason why it wouldnīt work, but is there a point in this concept?
Old 24th April 2004, 03:46 PM   #3
cuallito is offline cuallito  United States
Why to be different of course!
Old 24th April 2004, 03:49 PM   #4
No, no point... except for re-using parts that I already have... and to be different off course...
Old 24th April 2004, 05:29 PM   #5
Eli Duttman is offline Eli Duttman  United States
A cautionary note: with simple cathode bias, the 4 "finals" have to be CLOSELY matched. Obtaining CLOSELY matched quads of 300Bs could be quite difficult.
Implementing Dennis Boyle's combination bias would provide a means by which imperfectly matched tubes are compenstated for.
Use unbypassed 220 Ohm cathode resistors "under" each "final". A bias supply combined with 4X individual bias adj. pots. allows the setting of the "finals" at identical idle currents.
Eli D.
Will this work? "Mixed" 300B PPP ITHide this!Advertise here!
How can I add a "Digital In" to my current cd player ? (Make it work as a DAC ) b_online Digital Source 3 29th October 2014 01:37 AM
"WTB" 300b Integrated or mono blocks markmelheim Swap Meet 0 19th February 2009 12:20 AM
How Do "Heat Fins" Work In a Vacuum? DaveMcLain Tubes / Valves 7 11th April 2008 11:49 PM
Randy Slone "Fig 11.6" amp, modded: will work? tcpip Solid State 85 29th May 2007 10:31 PM
Can anyone suggest the "best" 300B SE sound quality schematic for a beginner like me? calico88 Tubes / Valves 42 18th July 2006 02:33 PM
Copyright ©1999-2017 diyAudio
