diyAudio Sponsor
Old 24th April 2004, 09:16 PM   #21
hacknet is offline hacknet  Singapore
one question, i recall EC8010 saying that David Hafler solve some oscillation problems by increasing the coupling capcacitors. the original issue uses a 0.25uf cap and the "revised" a 0.22uf. could i be a smart **** by putting 0.47uf?
Old 24th April 2004, 09:43 PM   #22
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
I've been searching desperately to find the article (I think it was Hafler), but I just can't seem to find it I have a feeling that the coupling capacitors were made quite a bit bigger, perhaps 1.5uF.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 24th April 2004, 09:50 PM   #23
SY's Avatar
Hafler and Keroes, Audio Engineering, reprinted in Audio Anthology v2, "Ultra-Linear Operation of the Williamson Amplifier".
from Hafler and Keroes
The low frequency time constants of the original circuit's interstage coupling networks were the same for both such networks. This is not particularly desirable in a feedback amplifier... Increasing one pair of coupling capacitors from 0.05uF to 0.25uF... increases the low frequency stability margin at nominal increase in cost.
"...we stumble and get up, we are sad, confident, insecure, feel loneliness and joy and love. There is nothing more; but I want nothing more.” - Christopher Hitchens 1949-2011
Old 24th April 2004, 10:31 PM   #24
EC8010's Avatar
SY: Thank you for that. I "knew" it was a factor of 5:1, hence my guess at 1.5uF!
Old 24th April 2004, 11:21 PM   #25
analog_sa's Avatar
Hacknet
Andy's suggested circuit is much better than a Williamson. That is if you want to build a modern sounding amp and not just something of historical value.
Going as far back as the sixties amp builders noticed the Williamson plays better in mono than stereo. Lots of NFB keeps the sound strictly in the speakers, kills dynamics and soundstaging and together with the excessively repetitive use of 6SN7 produces cold and boring (for a tube amp) mids.
Old 24th April 2004, 11:37 PM   #26
diyAudio Senior Member
fdegrove's Avatar
As an example:
I have a PP 2A3 amp that uses only local FB, no global loop whatsoever...
The soundstage that little amp can throw is little short of amazing.
With any decent recording you can plunk the speakers down, even only 4-5 foot apart, you just can't tell the sound comes from those speakers.
That's not to say the amp is perfect, it isn't.
For what it cost me however it's a joy to listen to.
Frank
Old 25th April 2004, 01:58 AM   #27
arnoldc is offline arnoldc  Philippines
Send a message via Yahoo to arnoldc
Originally posted by fdegrove
[B]I have a PP 2A3 amp that uses only local FB, no global loop whatsoever...
Hi Frank, i've been wanting to make a PP 2A3 and been contemplating on the JE Labs PP 2A3. However, I want to try one of yours. Is that at all possible? Share the schematic or is this a commercial amp?
Old 25th April 2004, 02:34 AM   #28
hmm... williamson or not williamson...
i`ll have a look and see what i decide on... the rest look quite game on a williamson.
Old 25th April 2004, 10:44 AM   #29
That's not to say the amp is perfect, it isn't. For what it cost me however it's a joy to listen to.>
That's exactly my response to taking off the global feedback loop - joy! The sound just makes you like it - happy pills. Haven't got a clue how this effect measures, but I was just grinning when I heard the sound without feedback. If I'm reading the language correctly, others seem to have a similar response. Not to say that others don't grin when they add feedback - I'm sure this happens too.
Old 25th April 2004, 01:02 PM   #30
what trans did you guys use? i`m considering a tamura or a custom winder.
whats a good diy tube preamp kit merickrc Tubes / Valves 40 28th March 2009 11:24 AM
Enclosure for Beyma 12CX - whats good? freddi Full Range 0 24th November 2006 05:12 PM
New stock pre -amp tubes. Whats good? RockysDad Tubes / Valves 7 3rd March 2006 10:46 PM
Whats a GOOD LM3875 chip amp circuit? matt_uk Chip Amps 5 14th November 2003 10:23 PM
Whats a good.. jleaman Multi-Way 6 9th November 2002 05:56 PM
Page generated in 0.12844 seconds (70.99% PHP - 29.01% MySQL) with 10 queries
