Old 25th April 2004, 04:14 PM   #21
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
The decision about whether to use feedback, or not, can be made after the event. The important choice is the output transformer. Valve amplifiers stand or fall by their output transformer. Shipping iron from the UK to Argentina is probably not economic (so how come we buy your corned beef?). I imagine something from the Hammond range ought to be suitable, but I'm sure there are people closer to you who will know.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 26th April 2004, 08:14 PM   #22
hi, thanks, i go for this 8k ohms 4 y8 ohms output (is right?). Another question, in power supply is better tube or diodes?, any tube (5u4, etc.) or the tube in the schematic is the only i can choose. Is so important than the output trafo or no .
Thanks, Federico
Old 26th April 2004, 08:27 PM   #23
diyAudio Senior Member
fdegrove's Avatar
If you want to copy-build the Leak TL 20 as you posted you'd better stick with the 5AR4/GZ34 rectifier as shown, otherwise you'll need to change too much.
In general most people building and enjoying tube amplifiers prefer to use tube rectifiers for mains rectification.
Frank
LEAK stereo 70 cutting out Minimuslover7 Solid State 10 24th August 2009 04:56 PM
Any Mods for a Noisy Leak Point one Stereo? fsjonsey Tubes / Valves 4 24th May 2008 03:34 PM
Replacing Valves Leak Stereo 20 pubrunner2000 Tubes / Valves 6 15th December 2007 01:01 AM
Leak stereo 70 fault harrygrey382 Solid State 16 25th February 2007 04:07 PM
Leak Stereo 20 questions Johan Potgieter Tubes / Valves 23 30th April 2006 11:57 PM
Copyright ©1999-2013 diyAudio
