#11 | |
diyAudio Moderator Emeritus
In most cases, you don't need a true-RMS DVM. The only time you need one is if you are concerned about heating effect and your waveform is distorted. We don't like distortion in audio, so a cheap and cheerful mean-sensing calibrated RMS of sine wave meter will do perfectly well. That is, any old £15 junk. My true-RMS meter (I wanted a 0.025% accuracy meter, and true-RMS was included) can display the AC and DC components independently, which is occasionally useful.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
#12 |
Thanks so much...
MB |
| mtx amp problem [[help!!]] | fuzzypinkhat45 | Car Audio | 3 | 8th July 2008 05:34 AM |
| CDM 2/29 Problem – HELP! | Bassivus | Digital Source | 29 | 23rd December 2007 10:00 AM |
| FRD/ZMA Problem | Twisted85 | Multi-Way | 5 | 4th December 2006 01:19 PM |
| p3a problem | MaXiZ | Solid State | 17 | 16th July 2005 07:14 AM |
