| Home | Forums | Articles | Links | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
| Tubes / Valves All about our sweet vacuum tubes :) |
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing |
Thread Tools |
this is my first time posting here. i have a pair of 6SN7GTBs and a pair of 6V6GTY tubes. i want to try building a SET amp preferably tube rectified using 5U4G. i'm looking for good schematic i can use. can anyone please help me?
#2 |
See: 12at7->6aq5 amp the 6AQ5 is electrically very similar to the 6V6, just can't handle quite as much plate voltage... Also 6SN7 -> 6550 amp
Neither of these is exactly what you're looking for, but there a good starting point... Peace |
#3 |
thanks for the reply. can't seem to open the suggested sites though.
#4 |
What sort of speakers are you planning to use the amp with? SE and triode strapped, a 6V6 will yield about 3 W. IMO, 98 dB. SPL speakers are indicated for 3 WPC amplification.
You could squeeze about 5 W. out of a 6V6 if it's wired UL SE. 95 dB. SPL speakers enter the picture at 5 WPC. Cascaded common cathode gain blocks will give you plenty of drive. Don't forget a decoupling filter in a 3 stage amp. Perhaps a DC coupling expert will help in setting up the 'SN7s; that would leave only 1 cap. (between the driver and 6V6) in the signal path. BTW, I tried the links Mr. Primrose provided. I get a page unavailable notification.
Eli D. |
#6 | |
thank you for the replies. i'm currently using an 8" single full range driver in a voigt pipe. my current amp which is a 2A3 can easily drive it to loud levels. just wanted to utilize these spare tubes. i already have a 6V6 push-pull amp so i wanted to build a another 6V6 amp but in a SET config. |
#7 |
http://www.boozhoundlabs.com/howto/
others here can comment on the optimum bias / load values cheers
"Any fool can know. The point is to understand" - Albert Einstein |
#8 |
frugal-phile(tm)
found on my hard drive...
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi |
#9 |
frugal-phile(tm)
more... 12AX7 + 6V6
#10 |
If you are into experimentation (!) maybe try it in pentode mode with a little negative feedback. I made one sound very good using this method.
6V6s are great tubes, better than those christmas-tree-light 6AQ5s! And they can easily handle 12W or more dissipation (5W audio in pentode mode) |
| Thread Tools | |
| Help me.......What is the 6SN7 ??????? | cd149dc | Tubes / Valves | 10 | 17th June 2007 05:09 PM |
| SE 6SN7 amp.... | JandG | Tubes / Valves | 17 | 4th March 2007 12:59 AM |
| Trade CSS FR125S for other driver or 6sn7 | TomekZ | Swap Meet | 1 | 14th December 2005 05:25 AM |
| 6sn7 pre | drobert | Tubes / Valves | 5 | 24th October 2005 01:13 AM |
| Suitable operating point for 6SN7 as a differential driver ? | ray_moth | Tubes / Valves | 15 | 27th October 2004 09:50 AM |
| Page generated in 0.18513799 seconds (82.85% PHP - 17.15% MySQL) with 11 queries |
