diyAudio Sponsor
Old 26th April 2004, 09:42 PM   #21
Instead of an "ordinary" 5Y3, spend a little extra and buy a 6087/5Y3WGTB. The 6087 has a cathode sleeve. The IDH signal tubes will last longer with a slow B+ rise. Prevent cathode stripping.
A 5V4 is another suitable 1/2 indirectly heated rectifier. The forward voltage drop in a 5V4 is less than that in a 5Y3.
Eli D.
Old 27th April 2004, 01:40 AM   #22
Eli Duttman,
do i have to change the values of the any of the parts in the power supply should i use 5Y3WGTB rather than 5y3 only?
Old 27th April 2004, 02:05 AM   #23
arnoldc is offline arnoldc  Philippines
Send a message via Yahoo to arnoldc
i am not Eli but i would say no. am i right Eli? and i'd say go for slow start rectifiers, or put in a stand by switch (which is mostly what i do). you don't have to limit your tube rectifier choices, find one that is slow start and which you will have a budget for, because 5AR4's are ridiculously high priced in the philippines. 5Y3 and a stand by switch a lot cheaper
once you have sorted out your choice, then we can design the PSU around that using PSUD.
Old 27th April 2004, 03:26 AM   #24
6087/5Y3WGTB replaces an "ordinary" 5Y3 without any circuit changes. Same story for the 6106. A 5Y3 with a slow B+ rise is nice. I use Raytheon 6087s in my DECWEAR SE84Bs, whose circuitry is also triode/triode strapped pentode.
If you use a 5V4, you will have to allow for a higher B+ rail voltage.
A way to get the slow B+ rise CHEAP is to use 2X 7Y4 Locktal tubes. In the US, Locktal sockets cost more than 7Y4s and 7Z4s do.
Eli D.
Old 27th April 2004, 03:50 AM   #25
Lico is offline Lico  United States
The first schematic planet10 posted is the one i built. here's the ps for it. Enjoy.
Andy
Old 27th April 2004, 04:10 AM   #26
Do you smell smoke?
Andy
You may want to re-think that, the 5V4 is rated for 10uF max for the first stage of a cap input filter...
Peace
Old 27th April 2004, 06:28 AM   #27
SHiFTY is offline SHiFTY  New Zealand
SHiFTY's Avatar
^^ Not according to the data I have... 32uF is the max input capacitance. 10uF is suggested, but you can use more as long as you don't go over peak current ratings. I would suggest something like 22uF for a 5V4.
Check this:
http://www.mif.pg.gda.pl/homepages/f.../001/5/5V4.gif
I use a Mullard GZ32, the nicest rectifier around! It is a 5V4 equiv.
Old 30th April 2004, 03:29 PM   #28
G is offline G  United States
G's Avatar
This is the Schematic of my SE EL84 amp. You will have to change the biasing of the output stage a little to use a 6V6 but everthing else should be the same. I'm king of busy today otherwise I would do the calculations for you and post them. Sorry.
Gavin
Old 30th April 2004, 03:34 PM   #29
G's Avatar
My apologies. THis is the correct schematic. Oops.
Gavin
Old 6th May 2004, 02:20 AM   #30
i decided to go for a 5u4g rectifier. i'll be using a power transformer rated at 300-0-300. can anyone please help me design the power supply if i require 250V B+ for the 6V6 and 180V for the 6sn7 driver. thanks
SE 6SN7 amp.... JandG Tubes / Valves 24 6th March 2011 12:37 PM
Help me.......What is the 6SN7 ??????? cd149dc Tubes / Valves 10 17th June 2007 05:09 PM
Trade CSS FR125S for other driver or 6sn7 TomekZ Swap Meet 1 14th December 2005 05:25 AM
6sn7 pre drobert Tubes / Valves 5 24th October 2005 01:13 AM
Suitable operating point for 6SN7 as a differential driver ? ray_moth Tubes / Valves 15 27th October 2004 09:50 AM
Page generated in 0.10513 seconds (78.26% PHP - 21.74% MySQL) with 11 queries
