| Home | Forums | Articles | Links | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
| Tubes / Valves All about our sweet vacuum tubes :) |
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing |
Thread Tools |
#11 |
camotecue,
You have high efficiency speakers. So, triode strapped 6V6s will be fine. Build a stereoblock from the schemo planet10 provided. Save the extra 6SN7 for the future, but you will replace the 6V6s long before the driver wears out.
Eli D. |
#12 |
planet10's schematic and my link are the same , ... the link i posted earlier gives you some background into the design process and construction, .. always useful for beginner.
cheers
"Any fool can know. The point is to understand" - Albert Einstein |
#13 |
thank you all guys for contributing to my query. it may be difficult to find 5Y3 tubes here in the Philippines. can you please help me design the power supply of the triode strapped-schematic as posted here in this thread by using 5u4g tube instead.
#14 | |
#15 |
6n8=6sn7
ÌìÉϰ×Óñ¾©£¬Îå¥ʮ¶þ³Ç¡£ ÏÉÈ˸§ÎÒ¶¥£¬½á·¢Êܳ¤Éú¡£ |
#16 | |
#17 |
5U4 and 5Y3 are pretty much the same, 5U4 has a 3A filament and can handle more B+ current. If your 5V filament winding can handle it, you can plug a 5U4 straight in.
Sorry no schematic, but the 1/2 12ax7 -> 6v6 posted earlier is pretty much identical. Just change the preamp anode and cathode resistors to suit 1/2 a 6SN7 instead of 12AX7. |
#18 | |
#19 |
5Y3 drops 60V compared to 45V of 5U4. in my 45 amp it was quite critical and i needed the 5Y3 because i goofed in the power transformer
camotecue, how many do you need? 2 pcs? |
#20 |
i think the single ended triode strapped 6V6 amp schematic in this thread requires only a single 5y3.
| Thread Tools | |
| Help me.......What is the 6SN7 ??????? | cd149dc | Tubes / Valves | 10 | 17th June 2007 05:09 PM |
| SE 6SN7 amp.... | JandG | Tubes / Valves | 17 | 4th March 2007 12:59 AM |
| Trade CSS FR125S for other driver or 6sn7 | TomekZ | Swap Meet | 1 | 14th December 2005 05:25 AM |
| 6sn7 pre | drobert | Tubes / Valves | 5 | 24th October 2005 01:13 AM |
| Suitable operating point for 6SN7 as a differential driver ? | ray_moth | Tubes / Valves | 15 | 27th October 2004 09:50 AM |
| Page generated in 0.17653704 seconds (81.12% PHP - 18.88% MySQL) with 11 queries |
