| diyAudio Sponsor | ||
Hii all!
I'm trying to build a 811-3 SE amp, and here is "my" preamp. It has a gain of about 25 with a load of 1Meg (the grid resistor I'm planning on using). As I'm a complete newbie I'd appreciate the help from all you gurus here... Do you guys think it will be enough, or will I need an extra cathode follower stage (or something else I haven't thought about...)? Is it possible to use a IT with this design ? Thanks -Miguel |
#2 | |
diyAudio Senior Member
Is that a 500V B+ you're using? Quote:
Frank |
#3 |
Hi
what is the purpose of the unbypassed 15k R18 resistor? Federico |
#4 | |||
100r from pre >-----####-----(Grid | # # 1Meg # | v B- Quote:
-Miguel |
#5 | |
As Frank hinted 1M is too much, especially if you intend using fixed bias. Try 200k as max value. I also don't see how are you going to get enough gain - you need something like 90v at the 811 grid if i am not mistaken. |
#6 | ||
... Why do you say that I must bypass it ?Quote:
130Vpp grid drive with -65V fixed bias and 450V plate 30Vpp grid drive with -165V fixed bias and 800V plate 280Vpp grid drive with -65V fixed bias and 450V plate I was aiming for the second one, but now that I think of it it may be a typo... The grid drive voltage is quite low compared to the others
#8 |
If you want the upper tube to act like a follower, eliminate the plate resistor. Then, since you're taking output from the cathode of this tube, you're basically getting CF behavior. You should have fairly low Zo ( not as low as a true follower). Also, depending on what you're driving, I think the 5u could become a 1u.
| A simple active DC dummy load for PSU testing | Bootstrapper | Power Supplies | 42 | 17th August 2008 09:57 PM |
| Dynamic load line analysis using music and speaker load | Michael Koster | Tubes / Valves | 0 | 7th March 2008 09:47 PM |
| Mu-follower vs common cathode w/- active load | jnb | Tubes / Valves | 7 | 24th June 2007 10:53 AM |
| Active load output stage | croccodillo | Tubes / Valves | 68 | 22nd January 2006 10:04 PM |
| active plate load v.s. constant current... | mwmitchell | Tubes / Valves | 3 | 8th August 2002 10:34 PM |
| Page generated in 0.08881 seconds (84.75% PHP - 15.25% MySQL) with 11 queries |
