| diyAudio Sponsor | ||
I plan to run the 6.3V filament power right from the bridge rectifier to each tube in a "daisy chain" manner. In an effort to keep this power line from affecting the audio signal I was going to use microphone cable (twisted pair with a mesh shield) for the power and ground only one side of the mesh shield. The grounding for the tubes will be one of the twisted pairs and the hot will be the other, this way the grounding for the tubes will exist at the power supply's star ground and not the signal's star ground.
Is this sufficient? Am I going overboard or am I missing something? Thank you for your help. Milo |
#2 |
Mike cable is often too thin to avoid drops at these currents. You'd do better to use properly-sized single conductor wire, with the two sides of the run tightly twisted together and the wire run close to the chassis.
"...we stumble and get up, we are sad, confident, insecure, feel loneliness and joy and love. There is nothing more; but I want nothing more.” - Christopher Hitchens 1949-2011 |
#3 |
Oh duh, that makes sense. Is it beneficial to shield the runs though?
Milo |
#4 |
If you take reasonable care to keep the high impedance leads away from the hummy stuff, there's probably no benefit. My power amp uses filament runs just like this and it's dead quiet.
Since you're powering the filaments with AC, this must not be a circuit which handles microvolts, which makes life easier.
#5 | ||
I use the method recommended in all classic books, that is for AC wiring use twisted wires and keep them away from signal wiring and put it close to the chassis. I use this method in my OTL and achieve hum level that is below 0,4mV Pk-Pk or <-100dB relative to full power. For preamps I use DC stabilised voltage for the heaters and therefore dont need to twist the wiring also in this case I have no problem to keep hum low and insignificant. (I use stabilised voltage due to 2 reasons, one is to reduce hum as much as possible and secondly to keep the voltage stable to minimise tube drift as I am using DC coupled gain stages) Note! tubes from some manufacturers are much more sensitive to heater induced hum then others so if you have a hum problem it can be beneficial to change tube to something from another manufacturer. Regards Hans |
#6 | |
diyAudio Senior Member
Twisting these very short runs of thick wire (2.5A per tube) is just a waste of time. The amps are still absolutely dead quiet even with 96dB + speakers. Note however that generally speaking one should twist the heater wires to avoid hum. In some situations I even twist them when they themselves carry DC to avoid break in influence from magnetic fields outside the wires . Cheers,
Frank |
#7 |
Thanks for the help folks.
Milo
How did I live without Nina Simone for so long? |
#8 |
It all depends on the signal voltage at the grid of the valve. Frank's 6080s have quite healthy signals, so he doesn't even need to twist his heater wires. I once made a phono stage where (due to poor layout) I had to screen the twisted pair carrying the AC heaters. It wasn't long before I changed those heaters to regulated DC. Twisting is usually sufficient, and if you need more than that, it's an indication that something is wrong. Most people use DC heaters as a matter of course on phono stages. Anywhere else, twisted pair AC is fine.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference... |
| Nonstandard tubes for audio? Quadrature grid chorus effect? | m6tt | Tubes / Valves | 2 | 30th January 2008 09:41 PM |
| Running different tubes | fauxpas | Tubes / Valves | 2 | 19th December 2007 01:25 PM |
| Running tubes at lower voltages | Redemption | Tubes / Valves | 23 | 4th January 2006 03:45 PM |
| Crucial to match tubes when running PSE? | G | Tubes / Valves | 25 | 25th September 2003 09:15 PM |
| Page generated in 0.10776 seconds (77.83% PHP - 22.17% MySQL) with 10 queries |
