help to chose Tube for my OPT Hashimoto H-20-14U (20W, 10K/14K Ohms)
Ex-Moderator
Joined 2011
See below.
suwaned,
You might try using an 807 Beam Power Tube in Triode Wired Mode.
Here is a link from this forum: Misty- SE 1625 Triode Strapped- Newest Build
I like that amplifier. I did my own 807 triode wired amplifier, but I did not make the circuit as good as rcollege's version. The 807 is a 6.3V filament version of the 1625 which has a 12.6V filament. Otherwise the two tube types are identical.
The transformer specs ought to be checked, before determining the maximum B+ to use.
If an output tube is cut off, the voltage can rise to 2X the B+, even with a load present.
Many of those transmitting tubes generally require voltages of 600, 700, 1000, 1200, etc. to operate very well.
