pentode noise and local feedback
Old 10th August 2018, 08:14 PM   #31
6A3sUMMER is offline 6A3sUMMER  United States
A CCS that is far from perfect, but has Very Low noise is . . .
An Inductor
The possible problems with using an inductor as a CCS are:
hum pickup from magnetic fields - noise
DCR - noise
Inductance too low - low impedance at low frequencies
Distributed capacitance - low impedance at high frequencies
Expense
Weight
Real Estate
I have used inductors as CCS in cathode coupled phase splitters; and also in self inverting cathode coupled push pull output stages.
I have also used inductors as CCS in SE output stages (output transformers); not many think of it as a CCS (It just happens to be in parallel with the reflected load).
There is very little noise from any of these inductors, the exceptions are listed above.
One thing about these inductors, they do not self oscillate.
pentode noise and local feedbackHide this!Advertise here!
Local Feedback for Push Pull Pentode dsavitsk Tubes / Valves 22 4th December 2013 06:48 AM
Powerdrive for PP amp with local feedback and pentode driver ? Jaap Tubes / Valves 5 5th November 2009 09:58 AM
Cascode with local feedback croccodillo Tubes / Valves 8 19th July 2007 03:30 PM
'Local Feedback and Nonlinearity of Multistage Feedback Amplifiers' mikeks Solid State 62 20th July 2005 08:03 AM
