Getter Temperature
Getter Temperature
Old 11th July 2018, 03:23 AM   #1
FullRangeMan is offline FullRangeMan  Brazil
FullRangeMan's Avatar
Default Getter Temperature
Found this image on web a few years ago, wonder which column refers to audio tubes?
I enlarged this picture 1400x866 hope it visible.
>Never go to a psychiatrist, adopt a cat or dog from the streets. On the streets pets live only two years average.
Old 11th July 2018, 08:22 AM   #2
JonSnell Electronic is offline JonSnell Electronic  United Kingdom
JonSnell Electronic's Avatar
The Getter activates at above 1200℉ or 690℃. Commonly placed inside an induction heater and of course, its design, is why it presents itself as a shorted turn to the eddy currents and heats up without affecting the anodes.
Support for Fender, Marshall and all Valve Equipment; Audio Innovations, Audiorama FU29, Quad and Leak. www.jonsnell.co.uk
Old 11th July 2018, 08:29 AM   #3
If you have the time, this is a YouTube link to Mullard Valve production, circa 1938.
Part of our heritage, hopefully never to be forgotten.
YouTube
Old 11th July 2018, 09:17 AM   #4
Merlinb is offline Merlinb  United Kingdom
Merlinb's Avatar
The one labelled 'Ba and Ba compounds'. Possibly also the last two columns before phosphorus, i.e. Batalum and Berylliata.
Buy my tube hi-fi book! www.valvewizard.co.uk
Old 11th July 2018, 09:36 PM   #5
Oh Nice. For these colunms the Range Temperature line is 20 - 200C.
So the Getter activation range start at 20C ??
Very easy for baking tubes in a electric owen.
Old 12th July 2018, 07:08 AM   #6
petertub is offline petertub  Sweden
One has to differentiate between activation ( the hot procedure that boils the
getter material onto the glass) and the longtime work done by the material
that is deposited on the glass.
The later is active at tube working temperature ( 100-200 degrees celcius ) and may be done in an household owen.
My home is at www.tubular-well.se
Old 12th July 2018, 07:46 AM   #7
Merlinb's Avatar
150-200 celsius is ideal. Man, my book is useful for everything! See:
Wolfe, G. (1962). Getters. In: RCA Electron Tube Division, Electron Tube Design, p522.
PDF here:
http://www.tubebooks.org/Books/Atwoo...e%20Design.pdf
Old 12th July 2018, 08:43 PM   #8
PDF here:
Thanks for the link Merlin and for the all the others replies boys
Appreciated
Getter TemperatureHide this!Advertise here!
Getter heater & B+ sequencing ? luckythedog Tubes / Valves 273 30th November 2014 02:57 AM
Tube getter M Gregg Tubes / Valves 8 4th May 2014 03:09 PM
What the heck does a getter do ? bereanbill Tubes / Valves 4 17th May 2009 07:51 PM
Detached getter? rknize Tubes / Valves 6 25th March 2009 05:32 AM
KT66 loosing its getter ixe13 Tubes / Valves 2 27th February 2008 01:33 AM
