Active LRC EQ
Active LRC EQ
Old 11th July 2018, 02:40 AM   #11
mashaffer is online now mashaffer  United States
Not as high of Q as I was expecting. I suspect a MOSFET would tighten it up a bit.
Now the big question why does it work? FB from plate to its own cathode?
The only reason I drive the 91 Colony Park is that I can't afford a 65. Me old school? Couldn't be.
Old 11th July 2018, 03:32 AM   #12
Miles Prower is offline Miles Prower  United States
Miles Prower's Avatar
Originally Posted by mashaffer View Post
Thank you. I like the looks of the cathodyne... Nice and simple.<snip>]
This schemo is very much like this one. When you see an arrangement like that, with the NFB connected to one side of a pot and the input to the other, you have a boost/cut circuit. At the approximate midpoint of the pot, the RLC suck-out filters drop out as they'll be connected to the neutral point. The three 12AX7 sections along the bottom form the "L" part of the filter as active "gyrators" to avoid coils and the associated problems of shielding against hum pick-up. You could ditch the three 12AX7's and replace with series coils to make passive filter sections. It would work the same.
Moving the center of the pot towards the input side removes those frequencies from the input (cut) and towards the NFB end removes them from the NFB (boost). If you had a feedback resistor to ground, you would have a boost circuit only, with no cut capability.
Vb is the non-invert bias voltage. since the op-amp is connected from 9.0V to ground instead of a balanced +/- supply, the non-invert terminal needs to be biased to 4.5V. The output stage naturally splits the voltage so the invert terminal already sees 4.5V.
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 11th July 2018, 06:11 AM   #13
Thank you Miles, that makes sense. I was piddling with a Mu Follower LTP and that might be a nice way to implement that.
So far this is the best I have come up with. The 30 Hz slider is a bit of a problem as both the coupling caps and the cap on the 30 Hz filter have to be made very much larger to get a 30 Hz center. Oddly if the filter cap (C1) is eliminated (shorted) correct center can be reached with only moderately big couplers.
Old 11th July 2018, 01:54 PM   #14
The solution seems to be quite simple. It turns out that eliminating the cathode coupling cap puts the center frequency spot on and alows the other coupling cap to be reduced. Of course that puts the filter network at about 100V so that some caps may need to be changed out due to voltage limitations but since the four lowest frequency are apparently polarized they would need to be changed out anyway. Fortunately the board is layed out such as to make those changes easy. I suspect that the coils themselves should be OK at that voltage.
Old 11th July 2018, 02:28 PM   #15
Tightens up the Q nicely too.
Active LRC EQHide this!Advertise here!
Help/recommendation - Presonus 2.0 active Monitors and active sub setup *photos Goremans Subwoofers 0 18th July 2016 01:20 AM
The Totem of Tone, an active 3-way dipole and active subwoofer Gerrit Boers Multi-Way 61 23rd May 2016 10:59 AM
Active 3-ways with solen active loudspeaker module soundemon Multi-Way 14 19th March 2009 11:17 AM
Behringer DCX2496 I want to try active biamping using it as the active xover. georgehifi Digital Line Level 3 15th August 2006 07:46 AM
XVR1 active crossover, discrete active stage promitheus Pass Labs 18 22nd July 2002 01:29 AM
