LED tube biasing, pros and cons
Old 11th July 2018, 05:26 PM   #91
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Just to throw some smoke into the discussion -- I used a current injector to look at the dynamic impedance of some older (pre-Avago) LED's and an Lite-ON Infra-Red device. First graph uses 1mA, the second 2.5mA:
Old 11th July 2018, 06:20 PM   #92
DAK808 is offline DAK808  United States
Pardon my ignorance but technically what is impedance magnitude. i have not seen that value on a graph before.
Old 11th July 2018, 07:21 PM   #93
jackinnj's Avatar
Ohms
Old 11th July 2018, 08:03 PM   #94
Why is there a question mark in parantheses?
Old 11th July 2018, 08:37 PM   #95
Merlinb is offline Merlinb  United Kingdom
Merlinb's Avatar
Originally Posted by 20to20 View Post
The voltage on the diode comes from the voltage through the tube.
The diode voltage is a function of the tube current. Voltage doesn't go 'through' anything. When the tube current gets very small, the diode voltage (i.e. bias) drops rapidly towards zero. But I don't understand what point you're making.
Buy my tube hi-fi book! www.valvewizard.co.uk
Old 11th July 2018, 08:46 PM   #96
trobbins is offline trobbins  Australia
trobbins's Avatar
jackinj, those are very interesting curves. Can you elaborate on what the test signal was, and the measurement circuit.
Old 11th July 2018, 09:13 PM   #97
jackinnj's Avatar
Artifact of converting image on the from the clipboard to MSPaint -- the "omega" doesn't make the transfer.
Old 11th July 2018, 09:55 PM   #98
jackinnj's Avatar
Test signal was 0 dBm. When I run the test at -30 dBm the low frequency dip is much less pronounced.
Test setup is from Omicron-Labs measurement of DC-Biased impedance:
https://www.omicron-lab.com/fileadmi..._Caps_V2_0.pdf
Old 11th July 2018, 10:20 PM   #99
trobbins's Avatar
For viewers without calculators, could provide those test signal levels in mA rms or pp?
Old 12th July 2018, 12:03 AM   #100
20to20 is offline 20to20  United States
The source of the voltage on the cathode is the voltage from the plate. Pull the cathode resistor and put your meter on the K pin. Wiz...
LED tube biasing, pros and consHide this!Advertise here!
Seen this ? Pros & cons. R Dijk Solid State 0 15th June 2018 09:01 PM
What are the pros and the cons of those 3 vas ? tessier Solid State 93 30th January 2017 01:53 PM
Cons / Pros Borat Tubes / Valves 34 1st September 2009 12:52 PM
pros/cons of a chipamp VS a tube amp jarthel Everything Else 2 22nd June 2007 01:18 PM
pros/cons of a 845 VS 211 jarthel Tubes / Valves 2 18th June 2007 12:57 PM
