Yet another valve pre, comments?! - Page 2 - diyAudio
Old 20th April 2004, 02:35 PM   #11
Mike C is offline Mike C  United Kingdom
Originally posted by Eli Duttman
The icing on the cake would be CCS loading the cathode follower with a pentode.
If one were to go to the trouble of adding another valve, especially
a pentode, I'd suggest using this as an anode load above the first
valve and of course removing the cathode follower.
This of course gives a Kimmel mu stage.
Then throw away the poor sounding 12AU7 and use say an E80CC instead
and you'll have a really fine sounding preamp.
It's called Nina, and the circuit and details are are on this board!
Old 20th April 2004, 11:11 PM   #12
An Alan Kimmel mu stage is TOO linear for my purposes, I want a SMALL amount of 2nd harmonic distortion.
I suggested a 'CG7 as the tube, not a 'U7.
CCS loaded cathode followers sound BETTER than resistively loaded CFs do. Pentodes make good current sinks, as do N-channel FETs and NPN BJTs. Why use "sand", when a tube will do?
Eli D.
Old 21st April 2004, 09:00 AM   #13
OK, I understand, so a normal triode with anode load resistor it is then.
Oops, sorry, I was looking at the original cct.
Fine, I accept this totally.
One thing to consider; how about just using a pentode as a cathode
follower? As I see it, the very high voltage gain gives good linearity,
and the generally highish Gm (relative to similar size triodes) will
give a low Zout, I think.
I wonder if, compared to triode CF with pentode sink, less might be more
if you see what I mean. I have no idea if that's right, just idly
speculating ...
Old 22nd April 2004, 02:24 AM   #14
"One thing to consider; how about just using a pentode as a cathode
follower? "
So here is your perfect exceuse to stock up on the 12BY7. Use 'em in the Cit.II or your linestage output. reisitive load will do the trick nicely, and at ~100 ohms output z, should drive your opt just fine.
regards,
Douglas
the Tnuctipun will return
Old 22nd April 2004, 02:36 AM   #15
diyAudio Senior Member
fdegrove's Avatar
Don't you mean CCS sunk CFs here?
I just want to avoid confusion before anyone asks where to put the CCS here.
Frank
Old 22nd April 2004, 03:04 AM   #16
In the case of cathode followers, CCS means constant current sink. Putting a CCS in the "tail" of a Schmidt phase splitter is the same thing, a current sink.
If it's in the plate circuit, it's a current source. If it's in the cathode circuit, it's a current sink.
Eli D.
Old 22nd April 2004, 03:23 AM   #17
fdegrove's Avatar
Default THE CONVENIENCE OF THE "S"...
Eli,
What I meant is the use of the verb "to load" in conjunction with the CF's CCS.
With the anode follower the CCS (Constant Current Source either way to make my life easier) is used as a replacement load for the commonly used anode (plate to you) resistor.
Whereas in terms of a cathode follower the CCS is used to sink current away from the cathode so it replaces the commonly used cathode resistor that's usually tied to ground.
It's a matter of semantics, I know.
Frank
Old 22nd April 2004, 03:35 AM   #18
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
It's a "source" if connecting its far end to 0V causes a regulated current to flow, and a "sink" if when connected to 0V, no current flows, but when conected to an appropriate (non-zero) potential, a regulated current flows. How about that? There's a really easy-to-follow, succinct description! No wonder there's confusion.
Pentodes cathode followers don't work quite as well as their high mu promises. Even after the voltage between g2 and cathode has been arranged to be (nearly) constant. A bit of a disappointment, really.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Convert a non-valve amp to a Valve (tube) Amp seanthomas46 Instruments and Amps 17 20th April 2015 05:11 AM
Swap Shanling CD-T80 valve CD player for Quad valve equiment johnm Swap Meet 2 24th September 2009 01:15 PM
Valve Art EL 156! Gydotron Tubes / Valves 1 16th February 2005 06:24 PM
Cheap valve pre-amp kit - comments please... adharvey Tubes / Valves 3 21st June 2003 09:51 AM
Copyright 1999-2017 diyAudio
