diyAudio Sponsor
Old 22nd April 2002, 09:03 PM   #1
Question Tube line-buffer for cd
Hello outthere,
I am a newbie on diy tube gear, but recently finished a push/pull diy kit using plitron output transformers and svetlana tubes (6n1p driver / kt-88 output) .
Until now it has a pot for volume adjustment (passive pre)
Because i have some parts left (elma 24 stepped att. and some 6n1p / 6922 / ecc88 tubes) a simple pre/line driver with low gain (max 4 or so) would be nice to give the amp some more juice.
Does anyone have a schematic i can use for building such a line buffer?? Preferably with low or no overall feedback at all??
Thanx,
Sander
Sander
Old 23rd April 2002, 12:36 PM   #2
tiroth is offline tiroth  United States
Check out the schematic I posted here. (the one at the end) I haven't actually built this yet, but it is a line buffer with a gain of 2.
As shown it is balanced input, but if you ground the inverting input and make your connection to the non-inverting input it will work fine single ended.
Decreasing the value of the degeneration resistors will increase the gain.
Old 23rd April 2002, 07:28 PM   #3
Thanx for your post, but i'm not looking for a balanced pre..
Does anyone have built this pre??
Any other suggestions from anybody??
Just looking for a pre with low gain using just one or two ecc88/6922/6n1p...
Sander,
The Netherlands
Sander
Old 24th April 2002, 09:14 AM   #4
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Hallo Sander,
Have a look at my preamp..it is quite simple to make but the results are great.
http://home.zonnet.nl/horneman
Old 2nd December 2002, 11:23 PM   #5
Hello Bas Horneman.
I am new in tube design, and I like to make a line amp capable of driving the Nelson Pass's Aleph 60 i have built.
I looked at your design (6n1p pre) , but I am not sure if it is a proper line stage for the mentioned amp.
The Aleph has a 48K input impedance, and is a DC couppled MOSFET class a design.
Also if you would be so kind specifying the in/output impedance, and gain.
Thanks,
Miki.
Old 3rd December 2002, 08:00 AM   #6
Hallo Miki,
Unfortunately I am an amateur and do not know how to calculate output impedance, gain etc.
What I would do is post and ask other diy'ers what they use with their Aleph 60..
What I do know is that the pre I once built..the 6n1p.. sounded quite good and is simple to make...
But how about the Bride of Zen pre amp also designed by Nelson Pass apparently it is a little beauty...
Old 3rd December 2002, 08:34 AM   #7
Thanks for your reply.
I heard once my Aleph with a tube preamp (a friend of mine lend to me for a few days...) and I was really impressed by the sound.
I have tried transistor/mostfet preamps, but I think that they performed worst.
And after all i'd like to see something GLOWING in my room ))
By the way, today I started to learn tube circuit theory, and soon I will be able to calculate myself the requested values )
Thanks again,
regards,
Miki.
Old 3rd December 2002, 08:45 AM   #8
Yes, it is very nice to see something glowing...
Good luck with your tube journey..I am sure you won't be dissapointed...it is very hard to make a tube amp that does not sound good...:-)
Greetings,
Bas
Old 3rd December 2002, 11:09 AM   #9
Hello again,
I read at your web page, that you had problems with the hum in the preamp, caused by non-groundig the heater circuit. How has to be grounded? Just put one of the transformer's 6.3V output to the ground? Or with a cap?
Thanks,
Miki.
Old 3rd December 2002, 11:29 AM   #10
Hi Miki,
Take 2 ..100ohm resistors.. solder to both legs of the 6,3 supply..
the 2 resistors then are both grounded..see picture.
Or get a centre tapped transformer...3,15v - 0 - 3,15v and ground the 0 volt tap. The3,15volt taps go to the heater of the tube
24v tube buffer & line stage schematic Bem-bem Tubes / Valves 18 16th December 2009 01:13 PM
Tube Line Buffer fossil2k Tubes / Valves 8 11th October 2007 07:29 AM
Buffer Line Pre-Amp Power Tx cantskienuf Tubes / Valves 0 10th March 2005 04:56 PM
BJT line buffer hjelm Solid State 0 30th March 2004 12:33 PM
Page generated in 0.10484 seconds (79.74% PHP - 20.26% MySQL) with 11 queries
