Sic for heaters, yes or not?
View Poll Results: Sic for heaters, yes or not?
Yes 0 0%
Not 2 100.00%
Voters: 2. You may not vote on this poll
Closed Thread
Old 14th June 2018, 01:45 PM   #11
Lingwendil is offline Lingwendil  United States
Now with high-fructose ASSAULT-gluten!
Lingwendil's Avatar
Increased voltage drop will cause higher dissipation at the currents we worry about for filaments, I doubt it will make much difference otherwise when used with inderectly heated cathode-type tubes, leave them to high voltage applications where their losses are negligible. UF-type diodes will be better for filaments.
Check out My 6SN7 Push-pull Flea Amplifier project! PCB COMING SOON!
Closed Thread
Sic for heaters, yes or not?Hide this!Advertise here!
6.5V on the heaters? diaz028 Instruments and Amps 8 3rd September 2015 10:34 AM
Heaters and centre tap duderduderini Tubes / Valves 10 17th November 2010 10:38 AM
AC wiring heaters, A or B ? zigzagflux Tubes / Valves 10 4th July 2008 09:43 PM
PSU for 12V DC heaters cbutterworth Tubes / Valves 15 9th March 2007 06:25 AM
Help with hum in AC heaters HeadSh0T Tubes / Valves 21 27th September 2003 12:40 AM
