First DIY tube amp
First DIY tube amp
Old 13th June 2018, 04:46 PM   #11
guitarnerd is offline guitarnerd  Taiwan
Good call, you're right C2 should connect the the anode of V1.
Yes, I'll look into LTP input stage and see how that goes. thx for the advise
Old 13th June 2018, 04:50 PM   #12
jazbo8 is offline jazbo8
jazbo8's Avatar
First DIY tube amp
Originally Posted by Sodacose View Post
See the well-documented AB input stages here for inspiration:
Do you mean even better documented than the Williamson amplifier?
Old 13th June 2018, 05:15 PM   #13
azazello is offline azazello  Bulgaria
azazello's Avatar
Down side of speaker must be grounded. Between pot. R22 and ground must be res. 5-10 kohm against full openning of tube. The same and for R23...
Projects: SE GK71, SE 12BQ6, PP KT88, OTL-OCL 6AS7 Gen. Electric, SEs 2A3 RCA, 300B JJ, 6S4S, 4P1L, EL11 Telefunken, 6AS7 RCA, 6S33S, 6S41S, 6S19P, E84L Siemens, E236L Telefunken, headphone ampl. OTL Loftin White 6AS7 RCA,...
Old 14th June 2018, 12:30 AM   #14
kward is offline kward  United States
To get 75 watts output in UL mode with KT88's, 6550's or equivalent, you'll need approximately 525V to 550V at the center taps of the output transformers with 4.3K to 5K primary impedance transformer and with 33% to 43% UL taps.
But the devil is in the details as they say. If this is your first attempt at scratch designing and building a power amp, I might suggest a simpler and lower wattage type for starters. I'm quite fond of my 6V6 amp that I re-engineered from a Motorola console. Twelve glorious watts!
Old 14th June 2018, 09:02 AM   #15
hooman is offline hooman  Iran
hooman's Avatar
hi
can explain about Williamson amplifier different to other pentode amps ?
nfb ?
pentode use ?
iranaudiotube.blogfa.com
1979.....i lost everything
Old 14th June 2018, 09:18 AM   #16
jazbo8's Avatar
First DIY tube amp
The Williamson amplifier is arguably the first "modern" tube amp design, first published in Wireless World back in 1947. Definitely pentode, as Williamson detested the "ultralinear" connection. There are literally hundreds of variants/clones of the Williamson amplifier since then, which you can find via a bit of Googling. Have fun!
Old 14th June 2018, 11:24 AM   #17
hooman's Avatar
first audio project should be push pull and made by popular hifi tubes . dont use compectron and tv h out like el509.....transmitter tube .....dht tubes like 2a3....6b4g...vt25...300b..
but 6l6gc.....el34....6v6.....el84....6550...kt88...kt 66... ecl86.. are easy to use .never use ac transformer in place of output chock .tube rectifier is safe for beginners amps .
Old 14th June 2018, 03:23 PM   #18
kodabmx is offline kodabmx  Canada
I've built seven amps using Triad VPT series power transformers as OPTs, including a KT120 triode push pull that makes 45W, 5W class A limit. If you use individual bias controls in fixed bias, an automatic bias board like the ones Pavel sells at audioamp.eu or either CCS cathode biasing or a garter circuit, they work very well. They can tolerate a slight DC unbalance, too.
I would suggest for a first time build to use cathode biasing for the simplicity of it. You can always modify it for fixed bias at a later time.
The Acrosound 6L6 build was my first build, and it sounded great from the first power up. http://www.keith-snook.info/amplifie...%20Rebuild.pdf
If you build the above, I suggest separate biasing resistors (R14) for each output tube. Simply double the value of the single resistor to achieve the same bias point. Bypass each one with it's own capacitor. I prefer 330uF instead of 100uF.
Old 14th June 2018, 08:19 PM   #19
Sodacose is offline Sodacose  United States
Sodacose's Avatar
Touche. But try asking Williamson for help if you don't understand something about his write up George, on the other hand, will probably chime in on this thread at some point if you ask him to or not!
WTF Amps || /r/diytubes/
Old 15th June 2018, 04:46 AM   #20
jazbo8's Avatar
First DIY tube amp
Just joking... George's design is a truly modern take on the classic design.
First DIY tube ampHide this!Advertise here!
Tube amp reboot Re: Chinese 6P6P (6V6) Push-Pull Tube Amplifier Kit ts761100 Tubes / Valves 14 31st March 2016 09:40 PM
5687 tube-based preamp with Tung-Sol Black plates, Sylvana and Phillips ECG tube pair networld Swap Meet 3 10th August 2014 01:23 AM
FS: Yaqin CD-1 Tube Buffer w/Mullard 6DJ8 Tube. Adds tube warmth to any system. matevana Swap Meet 2 15th June 2013 12:35 PM
need diy tube preamp (line-stage) recommendation and general tube advice Musiclover4 Tubes / Valves 16 18th May 2013 03:19 PM
found tube i like, only small bits of red letter,what tube brands used red lettering? ryuji Tubes / Valves 2 15th April 2011 11:24 PM
