Theoretical question about interstage transformers
Old 13th June 2018, 05:02 AM   #21
popilin is offline popilin  Argentina
popilin's Avatar
Our venerable Kondo San was a professor of electronic engineering and molecular metallurgy, one of his design goals with his Ongaku was the minimal use of iron, not a very popular idea though.
Originally Posted by DF96 View Post
A coupling cap is cheaper, smaller, wider bandwidth, less distorting, less prone to hum pickup etc.
Absolutely agree, the curious is that folks who hate capacitors are fans of interstage transformers.
Faradophobia, I guess...
Originally Posted by Zoran View Post
Try to understand two types of interstage. one with magnetization current and other without.
Could you please explain how does a transformer work without magnetization current?
I do not suffer from insanity, I enjoy every minute of it. - Edgar Allan Poe
He has the most who is most content with the least. - Diogenes of Sinope
Old 13th June 2018, 08:52 AM   #22
45 is offline 45  Italy
45's Avatar
I am afraid Juan but Kondo San made for himself things that he never put for sale and are better than his commercial products. In fact he possibly used those personal items for reference! Business and personal reference not always match....
Something like this "funny" looking thing:
YouTube
Having said that I have myself amps that follow his commercial and successful designs like the Neiro.
Originally Posted by kodabmx View Post
I think it's a good general representation. Only a fool would pay 400+ dollars for an IT when a great tube based circuit would cost about 50 IMHO.
Also I should mention that I was running open loop.
If I had $100 I would never spend 50 on a basic IT and 50 for the rest of the amp. Instead a proper $400 IT not only will have perfect 10 KHz square waves but also BEYOND 20 KHz perfect square waves which means extended and smooth frequency response (that also facilitates the application of feedback), generous inductance and headroom. A minimum of 200 KHz bandwidth is not just no match for the Hammond but very often even for RC or directly coupled stages!
These two IT's below cost actually about $325. The first is for SE and the second for PP:
http://www.monolithmagnetics.com/sit...im%20rev01.pdf
http://www.monolithmagnetics.com/sit...r%20prelim.pdf
N.B.
The 50pF cap in the load is not necessary anymore when the power tube is connected.
This one costs more because it is more complex to make but achieves the same minimum 200KHz bandwidth without bifilar winding:
http://www.monolithmagnetics.com/sit...20rev%2001.pdf
It's impossible to get blood out of turnips.
Old 13th June 2018, 12:07 PM   #23
TheGimp is offline TheGimp  United States
TheGimp's Avatar
How would one drive IT-02?
"Gapless design (no dc current allowed)".
Parafeed?
If there are no dogs in Heaven, I don't want to go there.
Old 13th June 2018, 12:21 PM   #24
45's Avatar
Parafeed?
The IT-02 is for PP. In reality can handle a small imbalance of approx.1-2 mA at expense of max output (which is more than enough anyway).
No parafeed for me. The SE versions are good enough.
Old 13th June 2018, 01:37 PM   #25
DF96 is offline DF96  England
Originally Posted by waxx
But each to his own off course, this is a subjective opinion.
You asked for a technical reason. I gave you a technical reason: low mu in DHTs. I also gave a social reason: nostalgia.
This is an objective fact: a coupling capacitor is much closer to being an ideal component than an interstage transformer. This, of course, says nothing whatsoever about which sound you will prefer; it merely says something about faithful reproduction of a signal.
Old 13th June 2018, 02:23 PM   #26
45's Avatar
It depends on the application. And it's just only about DHT's. Have you ever measured how much grid current a common EL34 can draw when approaching full modulation (Class AB1)? When a smallish grid current will appear things will be the other way around with the capacitor being anything but ideal or nearby. So one either uses a transformer or proper DC coupled stage that can handle that. None of the latter solutions are common in mass production. RC coupling in power amps is mostly for mass production because is cheap and simple. Surely not the best. It might be the best option in some cases where grid current is not a concern.
Old 13th June 2018, 02:58 PM   #27
GoatGuy is offline GoatGuy  United States
GoatGuy's Avatar
Originally Posted by 45 View Post
With a smallish grid current … a capacitor isn't ideal. But… a transformer or proper DC coupled stage can handle this.
Or, a sufficiently large coupling capacitor.
One of the reasons coupling capacitors — ones far, far from ideal — get “a clean pass” in service as DC blocking AC pass-thru interstage elements (contrary to the majority of hullabaloo regarding being 'there') is because as DF96 once made me realize, interstage transformers pass almost no current nominally. Relatively-negatively biassed input grids conduct very little current — those (again hat-tip to DF96) some grid current is expected.
At very high loading impedance, even a smallish interstage coupling cap has an audio-range attenuation approaching zero at the lowest audible frequencies. But as you note, that situation changes dramatically as soon as the downwind load becomes appreciably greater than near-zero-current.
Yet the solution is so straight forward that I find it amusing that it is so often overlooked: estimate the grid impedance when operating at positive instantaneous input grid conditions, then calculate at 10 Hz what value of interstage coupling capacitor would really be needed to deliver that current without appreciable attenuation.
Voilá. Then the bumped up interstage capacitor is just as applicable serving duty to remove the previous stage's DC anode influence, as the interstage transformer. And per what I wrote in my original comment here, with modern ultra-performance plastic films and evaporated aluminum 'plates', surprisingly high value non-electrolytic capacitors are readily available, and far smaller than a woodchuck in form factor.
Just saying. You can get there from here with capacitors. Just takes some calculating and adjusted component values.
GoatGuy
John Curl's Golden Rule…: 100 kHz bandwidth, 3 μs risetime, 100 W mean output, 100 V/μs slew rate, 2 Ω dynamic load, 20 amp min current source/sink
Old 13th June 2018, 03:05 PM   #28
popilin's Avatar
Sure, maybe in his intimacy he used SS amplifiers, it would be another possibility...
Neiro shows a classic design from Kondo San, 5687 cathode follower DC coupled to output valves.
Pierpaolo, we are talking about reasonable designs, even being myself a dumb designer I am aware of blocking distortion.
In 300B based amplifiers, an interstage transformer maybe would help with third harmonic distortion cancellation, the only reason which comes to mind.
Old 13th June 2018, 03:22 PM   #29
45's Avatar
Unfortunately sufficiently large capacitor often means less ideal. Have a look at manufacturers datasheet and you will see that 1 uF, often less, is more or less a threshold for higher losses. Capacitors have hysteresis themselves....are not ideal at all in the exact meaning of the word!
Old 13th June 2018, 03:34 PM   #30
45's Avatar
Pierpaolo, we are talking about reasonable designs...
I am too. I have bought a pair of used LL-1635 from a user of this forum for my latest amp at less than half price. If you buy 2x high quality coupling caps they will cost more! So if one doesn't want to spend much can look at the used market...just an example. Cheap capacitors have non-negligible losses.
Apart from this, cost is subjective and there is no technical argument that will change that!
Not to mention that I can take the supply for the driver from the 250V regulated supply of the power stage. With 205V supply (190V anode voltage and the rest for bias and transformer drop) I can get the full drive which is 138V grid-to-grid. See what you need with RC coupling to get that drive with the same very low distortion....added cost for the power supply at least!!!
Theoretical question about interstage transformersHide this!Advertise here!
Interstage transformer theoretical phase change? scutterflux Tubes / Valves 10 1st October 2013 04:08 PM
Theoretical OPT question weinstro Tubes / Valves 4 10th November 2008 08:54 PM
Theoretical sub/sat integation question morbo Subwoofers 0 28th September 2005 10:37 PM
Horns theoretical question johninCR Multi-Way 9 16th November 2004 11:08 AM
theoretical question.... weissi Digital Source 15 23rd May 2003 05:00 PM
