Building a Tube Mic Pre
Old 15th April 2004, 10:09 PM   #1
Chocolatemotor is offline Chocolatemotor  United States
Default Building a Tube Mic Pre
I have a small amount of knowledge of electronics, but I am extremely interested in building a tube Mic Pre. Does any have plans/ schematics in order to do this?
I would most most likely benefit from a simple plan to start.
Thanks!
Old 17th April 2004, 01:31 AM   #2
Eli Duttman is offline Eli Duttman  United States
For a mic with LOW O/P, the circuitry used in a phono stage, minus the equalization network, will work. Moving magnet phono cartridges have O/Ps of about 5 mV.
Here's a URL for a pentode (EF86) based circuit that makes a nice mic preamp.
http://www.svetlana.com/graphics/TB/no.23fig1.jpg
Eli D.
Old 17th April 2004, 01:51 PM   #3
Frank Berry is offline Frank Berry  United States
Frank Berry's Avatar
Please give me more information.
Balanced or unbalanced input?
Balanced or unbalanced output?
I designed a tube microphone preamp for a local CBS/Infinity radio station a few years ago.
I used a single 6922 tube in an SRPP configuration.
The preamp sounded better than the squalid state preamp that was in their mixing console.
Frank
Old 17th April 2004, 01:53 PM   #4
fdegrove is offline fdegrove  Europe
diyAudio Senior Member
fdegrove's Avatar
Input is usually unbalanced,output is balanced using an impedance xformer.
Frank
Old 17th April 2004, 02:06 PM   #5
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Sorry, Frank, but studio microphones are all balanced devices, and condenser microphones may need phantom power (+48V from 3k4 source impedance) connected between the centre tap of the input transformer and ground.
To be honest, I wouldn't have said that a microphone amplifier is an ideal first valve project. As has already been noted, the problems and solutions of RIAA preamplifiers and microphone amplifiers are very similar. They're both quite hard to do well. Of course, if the amplifier is to be matched to a single (known) microphone, to be used in a single (known) way, such as a presenter's microphone, life might be a lot easier. A universal microphone amplifier that can cope with inputs ranging from a ribbon microphone being used in a Blumlein pair to a large capsule condenser microphone in front of a saxophone is much harder.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 17th April 2004, 02:11 PM   #6
"studio microphones are all balanced devices, and condenser microphones may need phantom power (+48V from 3k4 source impedance)"
Correct.
I also provided a balanced 48 volt phantom voltage in my design.
Frank
Old 17th April 2004, 04:46 PM   #7
fdegrove's Avatar
Sorry. I should have been more explicit...
What I meant was that most mike preamps I've seen have single ended active circuitry.
So most of the time_ I'm aware of_ you have impedance xformer balanced in, to SE out, amplifying stage, SE into xformer and balanced out again.
GYRAF
Frank
Old 17th April 2004, 05:12 PM   #8
"Input is usually unbalanced,output is balanced using an impedance xformer."
Frank,
Don't try to explain yourself out of that statement ... Just say "I was wrong."
Want to ask how many times I've had to admit the same?
Another Frank who tends to agree with fdegrove most of the time.
Frank
Old 17th April 2004, 05:57 PM   #9
>>Want to ask how many times I've had to admit the same?<<
MUCH more than I care to admit!
Eli D.
Old 17th April 2004, 06:05 PM   #10
fdegrove's Avatar
Only when I actually am wrong....
We're talking about mic pre design not microphone design, so unless you need to design the input trannies yourself, the question at hand was: do you need a balanced or single ended design.
The only thing "wrong" was the way I put it, I suppose. Hence the clarification.
Let's agree to disagree....
Frank
Building a Tube Mic PreHide this!Advertise here!
Building RH84 SE tube amp. Forsman Tubes / Valves 160 29th September 2014 12:33 AM
Building a tube Model???? SGregory Tubes / Valves 1 20th October 2004 01:51 PM
Building tube stage with PCB, why? Bas Tubes / Valves 62 10th February 2004 03:40 PM
First time building a tube amp: Help please JAZZ2250 Tubes / Valves 36 28th June 2003 09:37 PM
Building First DIY SS or Tube??? d-audi Solid State 10 9th October 2002 08:00 AM
