Building a Tube Mic Pre
Old 17th April 2004, 08:12 PM   #11
Frank Berry is offline Frank Berry  United States
Frank Berry's Avatar
You're the one that brought up the output transformer without mentioning an input transformer.
So ... do you only design output transformers?
Sorry Frank. I'm just being nasty. I know full well what you were saying. I respect you for your ballz.
Frank
Old 17th April 2004, 08:50 PM   #12
Da5id4Vz is offline Da5id4Vz  United States
Da5id4Vz's Avatar
Send a message via AIM to Da5id4Vz
You might want to check out this link:
http://recordist.com/ampex/apxschem.html
Scroll down to the MR-70 record/Play amplifier. There are also drawing s for 50 and 60 dB mic pre mods for theses things.
Its a highly regarded amplifier for R-R machines and I understand that one of the reasons its been becoming increasingly scares is its popularity as a mic Pre.
-Dave
Old 18th April 2004, 06:07 AM   #13
electronaut is offline electronaut  United States
ChocolateMotor,
I agree that building a tube mic preamp is a bold endeavor, especially if you've never built a tube amp before, let alone a preamp. I started down that path myself and a couple of years went by before I had a solidly reliable unit.
Of course, there are easier paths -- if you can find a kit, that would be a great way to start. Definitely check out the Gyraf project. Also, for a copy of just about every mic preamp schematic known to human kind, you can go to Pat's Tube Schematics
And there's also a version of the Altec 1566 that I think you can buy in kit form.
Lastly, a guy named Greg Norman who works for Steve Albini's Electrical Audio studios here in Chicago modified the classic Ampex 350 electronics into mic preamps. The report is available here.
Hope that helps. Good luck!!
E. Lectreau
'You know you've achieved perfection in design, not when you have nothing more to add, but when you have nothing more to take away.' -- Antoine de Saint Exupery
Old 18th April 2004, 07:21 AM   #14
EC8010 is offline EC8010  United Kingdom
diyAudio Moderator Emeritus
EC8010's Avatar
Hello electronaut. I looked at "Pat's Tube Schematics", and although he beats his drum hard, I didn't see anything that made me think "gosh, that's clever, I'll have to try that". I'll probably be rained on for saying it, but most of the "engineers" in the music industry would be flummoxed by Kirchoff or Thevenin, let alone anything more complex.
Once Chocolatemotor gives some details of what he needs, we might be able to move on from mere speculation.
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 18th April 2004, 04:01 PM   #15
Well, I referred ChocolateMotor to Pat's Tube Schematics not because of how good or bad of an engineer Pat might be, but because he might be a good resource for schematics, especially if ChocolateMotor has a favorite preamp he might want to start with or something.
You are right about Pat beating his drum hard -- I guess I usually ignore those things and didn't take much notice, frankly.
Old 19th April 2004, 01:21 AM   #16
Da5id4Vz's Avatar
I think I can count on one hand the number of recording engineers I know of who are also Electrical Engineers. Perhaps on one finger (no not that one) because I donít think George Massenburg finished his degree. Tom Scholtz however may be the only MIT grad with more than one platinum album.
Likewise here at DIY we see some who are great EE and knowledgeable about audio as well as practitioners who also do a fine job.
I guess Im not to sure I understand what your getting at.
I posted this link:
because it has virtually every schematic for Ampex tape rec/play amps.
I think the MR-70 was the tube RC amp for the AG-350.
Old 19th April 2004, 11:01 PM   #17
thoriated is offline thoriated  United States
The MR 70 was the last vacuum tube model audio tape recorder Ampex made, and used nuvistors.
Old 19th April 2004, 11:26 PM   #18
EC8010's Avatar
Originally posted by Da5id4Vz
I guess I'm not too sure I understand what you're getting at.
I don't have a problem with studio operators preferring one piece of kit over another. Microphones are certainly different, and you need to select the right tool for the job. What I do have a problem with is when they start thinking they can fiddle with the insides of electronics and make design choices without having any knowledge of the engineering involved. Those older designs were carefully thought through by chaps with slide rules. Admittedly, their designs can often be improved by substituting modern components, but only if you understand what the original designers were doing in the first place. Thus, I find a lot of modern non-engneering-based tub-thumping rather insulting.
EC8010: Grumpy dyed-in-the-wool engineer who has listened at both ends of the chain.
Old 20th April 2004, 01:16 AM   #19
Da5id4Vz's Avatar
Well Said.
Back in the old days when I was still in "the business" I found that moderate success was often built on image and attitude. The truly talented could make a living without such grand posturing.
Tub Thumping! Boy doesnít that say it well.
I suppose for my part I should go back and read the mans article to see what he's all about. After all I have declared myself an MR-70 fan.
-Dave
Old 20th April 2004, 01:48 AM   #20
EC8010's Avatar
Yes, I noticed that (6CW7). And as they're so small, it just cries out to be hung from the back of the microphone - allowing sensible signals to travel to the desk.
Will we ever hear from Chocolatemotor?
Building a Tube Mic PreHide this!Advertise here!
Building RH84 SE tube amp. Forsman Tubes / Valves 160 29th September 2014 01:33 AM
Building a tube Model???? SGregory Tubes / Valves 1 20th October 2004 02:51 PM
Building tube stage with PCB, why? Bas Tubes / Valves 62 10th February 2004 04:40 PM
First time building a tube amp: Help please JAZZ2250 Tubes / Valves 36 28th June 2003 10:37 PM
Building First DIY SS or Tube??? d-audi Solid State 10 9th October 2002 09:00 AM
