DIY tube integrated for relative beginner
Hi all. My wife has approved an integrated tube amp purchase for our living room. I want to power my Kef Q100 speakers
(Kef Q100 specs are: FREQUENCY RESPONSE 49Hz - 40kHz (±3dB) CROSSOVER FREQUENCIES 2.5kHz MAXIMUM OUTPUT 107dB (SPL) AMPLIFIER REQUIREMENTS 10 - 100W SENSITIVITY 86dB (2.83V/1m)IMPEDANCE 8 Ohms).
I want to DIY this amp. I am relatively new to electronics, but I don't mind taking on a challenging project.
Can anyone recommend a diy tube kit amp with reasonable build guides that would be suitable for this?
Budget is about US$500 (which eliminated frequently recommended diy amps like bottlehead).
Thanks!
Here in the UK, a high standard is set in integrated valve amplifier kits by:
index
The prices, particularly when shipping is added, are above your budget. However it is worth looking at the site, if only to see the quality that is obtainable in a tube amplifier kit.
The KEL84 15W sells for £795 and the KT88 35W sells for £1,345.
Hi Moon Indigo!
Re Elekit TU-8200DX. The price looks good but costs may have been saved in the choice of output transformers. The fact that they are physically quite small may ultimately restrict bass quality.
Being a single-ended configuration the power output is quite low at 8.2W maximum. This is less than may be comfortable with your speakers. The kits I mentioned are push-pull configuration and consequently more powerful. Worth making the comparison to help guide your search.
If you are in Australia -> SS with H2 predominant like SE tubes amplifiers.
SAKSA 85
http://www.diyaudio.com/forums/aksa/
You can build it easy.
Aspen SAKSA85 amplifier - Product Reviews & Opinions - StereoNET
URL]
