Filaments DC or AC?
Filaments DC or AC?
View Poll Results: What do you prefer for heating AC or DC?
AC 38 38.78%
DC 60 61.22%
Voters: 98. You may not vote on this poll
Old 14th June 2018, 12:03 AM   #181
kodabmx is offline kodabmx  Canada
I use these: MINI DC-AC Inverter 12V To 18V220V/380V 500W Boost Step UP Power Module New Hot | eBay
For a power amp...DC-DC 8-32V to +-45V-390V Step-up ZVS High Voltage Capacitor Module Charge Board | eBay
For a simple line stage or negative bias supply. DC-AC Converter 12V to 110V 200V 220V 280V 150W Inverter Boost Board Transformer | eBay
And this for a preamp or medium power application. They all work flawlessly and have no measurable noise at the plates of the tubes. I use HER208 diode for lower power, and UF5408 for the power amps. I even use a Delon voltage doubler on the medium powered one to get 420V for a driver stage...
Old 14th June 2018, 01:14 AM   #182
gabdx is offline gabdx  Canada
They are AC output, I am confused.
amplificateurslegrand.ca
Old 14th June 2018, 03:40 AM   #183
popilin is offline popilin  Argentina
popilin's Avatar
Originally Posted by gabdx View Post
I am confused.
I knew it since post#28, no offence, just kidding.
I do not suffer from insanity, I enjoy every minute of it. - Edgar Allan Poe
He has the most who is most content with the least. - Diogenes of Sinope
Old 14th June 2018, 01:09 PM   #184
That's why I also said which diodes I use. BTW 2 of the three I posted have DC output built in.
Old 14th June 2018, 01:14 PM   #185
Also the formatting got screwed on that post. Sorry about that.
The 500W has only AC output, and I use UF5408 as a bridge.
Old 15th June 2018, 06:56 AM   #186
NuClear235 is offline NuClear235  Czech Republic
I ordered
DC-DC 8~32V to 45~390V High Voltage Boost Converter ZVS Step-up Booster Module 890270282639 | eBay
So I hope will be ok for my tube headphone amp. (Clone of Little Dot 2).
It needs 175V AC or 230 DC.
I have transformer with 16V AC out. What a pitty is not on this booster integrated rectifier and filter... I have to insert more module.
Next I will add DC filament stabilizer.
Old 15th June 2018, 08:33 AM   #187
trobbins is offline trobbins  Australia
trobbins's Avatar
A full-bridge of UF4007 or similar smd will give you 230VDC with 12VDC in, when using the 0-220V output winding.
I'd recommend using a commercial AC/DC smps power supply plug-pack with regulated 12VDC output to provide power for heaters and to the step-up module, then you have a regulated B+ as well, and no need for any AC wiring/safety concerns.
Old 17th June 2018, 02:20 AM   #188
santitrucco is offline santitrucco  Argentina
Default AC or DC filament 300B tube?
Hi friends, I have a new ask?
Why?
Old 18th June 2018, 02:09 AM   #189
6A3sUMMER is offline 6A3sUMMER  United States
IMHO,
If you like 100Hz/120Hz intermodulation tones on each music note or music tone, then use AC filaments on the 300B.
And even with no signal applied and AC filaments on the 300B, you are not likely to get hum down to less than 500 or 1000uV (0.5 to 1 mV).
DC is more trouble to implement, but does not have the above problems.
Read all 189 posts of this thread, and see if you believe my conclusions.
Old 18th June 2018, 10:57 AM   #190
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Why?
General consensus is DC for DHT heaters.
Filaments DC or AC?Hide this!Advertise here!
Filaments for 307A merlin el mago Tubes / Valves 58 24th December 2017 06:25 PM
What to start first B+ or filaments? merlin el mago Tubes / Valves 18 20th November 2017 03:46 PM
SMPS for Filaments? dshortt9 Tubes / Valves 2 16th January 2010 07:32 PM
CCS Design for DHT Filaments dsavitsk Tubes / Valves 9 29th April 2008 06:56 PM
Alloys for filaments Calvin Tubes / Valves 6 16th August 2007 12:41 PM
Resources saved on this page: MySQL 68.18% / PHP 59.48%
