D3A-300B Amplifier
D3A-300B Amplifier
Old 13th June 2018, 08:53 PM   #71
santitrucco is offline santitrucco  Argentina
Old 14th June 2018, 05:08 AM   #72
popilin is offline popilin  Argentina
popilin's Avatar
Originally Posted by rongon View Post
If trying to fulfill popilin's suggestion, you'd need to find a triode with so-so linearity, high mu, and high gm.
That's the idea, a mu follower and a source follower DC coupled to 300B.
6GK5 also works very well in simulations, but was discarded for aesthetic reasons and the difficulties to obtain 7 pin sockets here in my country.
I do not suffer from insanity, I enjoy every minute of it. - Edgar Allan Poe
He has the most who is most content with the least. - Diogenes of Sinope
Old 14th June 2018, 04:16 PM   #73
I have a lot of E180F tubes , i put plug & play them , and the amplifier play music wonderful..170v 18ma ..
May be is not so powerful like d3A tube , but is enough..
Old 18th June 2018, 04:04 PM   #74
Default Cathode 300B motor run Capacitors ?
Is good option to use 100uf MKP motor run in cathode 300B tube for replacement electrolytic capacitor ?
I have a lot of room..
Santiago
Old 19th June 2018, 06:05 PM   #75
kmtang is offline kmtang  Canada
kmtang's Avatar
It is good to try. Different kind of capacitor will have different sound.
It is hard to know what is your cup of tea.
Johnny
Old 19th June 2018, 06:11 PM   #76
kevinkr's Avatar
D3A-300B Amplifier
Yes, they can work well.. I like ASC motor runs. In addition to the 100uF cathode bypass motor run you can add a 20uF film cap from the cathode cap (filament end) to the B+, this will provide some canceling of ripple on the power supply.
Don't confuse motor run and motor start caps, you want run caps.. The start caps are usually short lived electrolytics.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 19th June 2018, 06:46 PM   #77
azazello is offline azazello  Bulgaria
azazello's Avatar
Santiago
Cap for cathode 300B must be best quality /it define quality of sound/ like Black Gate, Rubycon, Elna, Nichikon. Every regular cap is not suitable....but You can try...
Projects: SE GK71, SE 12BQ6, PP KT88, OTL-OCL 6AS7 Gen. Electric, SEs 2A3 RCA, 300B JJ, 6S4S, 4P1L, EL11 Telefunken, 6AS7 RCA, 6S33S, 6S41S, 6S19P, E84L Siemens, E236L Telefunken, headphone ampl. OTL Loftin White 6AS7 RCA,...
Old 20th June 2018, 03:45 AM   #78
soulmerchant is offline soulmerchant  Switzerland
soulmerchant's Avatar
I am doing ultrapath with DC Link film capacitors. Not so expensive, and better IMHO than electrolytics such as Elna cerafine or Nichicon muse. I prefer them to the crazy expensive black gates too...
To cancel any residual PSU ripple, CR couple power cathode to input/driver cathode (like original loftin-white circuit).
Ian
It's harder to make real audio than special effects audio.
Alejandro Gonzalez Inarritu
Old 20th June 2018, 01:37 PM   #79
juanitox is offline juanitox  France
juanitox's Avatar
for my own DRD or loftin white Set amp i always prefer the usual bypass cap to ground with big film caps than any ultrapath type as it always bring some positive feedbach ( sounds more natural without for my ears).
French is not a crime.
Old 20th June 2018, 04:10 PM   #80
Is true that electrolytic Mundorf ECap 63V capacitors are so good that films in place bypass cathode ?
D3A-300B AmplifierHide this!Advertise here!
New 300B - TJ Full Music 300B CNE DIY Hifi Supply DIY HiFi Supply 15 22nd June 2017 05:39 PM
D3a-300b amp help! gmant123 Tubes / Valves 13 19th March 2013 10:22 AM
FS: for 300B (JE Labs 300B SE) builders cartman Swap Meet 2 29th October 2008 01:13 PM
* 35 watt * 300B SE = super 300B + Class A2 rick57 Tubes / Valves 4 13th July 2005 04:18 PM
