How hot is "too Hot" for a transformer?
An amp being discussed today is Class A until about 4w per channel, then switches to AB as it continues to around 250w. I expect any amp that makes a switch like this, could consume a little more before the crossover, than it does immediately after.
Maybe? I dunno. Non contact thermometers are getting so cheap that everyone could have one now though.
Just for information, every 10 deg drop in temperature will approx. double the lifetime
This applies when temp > about 70C (very VERY hot to the touch), according to a chemist/materials guru I have at work. Below that the lifetime/temp is not as rapid.
(The 10degree/half-life rule of thumb is still used tho b/c of it's simplicity, gives an idea of heat/lifespan, and is still tought to military techs, u know the young, dumb, and full of guts&glory types)
