Noise: cheap power inverter for series heater string
Old 16th May 2018, 10:59 AM   #11
Tubelab_com is online now Tubelab_com  United States
Tubelab_com's Avatar
Stick the words "boost converter" into Amazon's search engine and see what turns up. There are plenty of "DC to DC 3.0-30 V to 5-35 V Output Voltage Adjustable Step-up Circuit Board" to choose from. Realize that the capabilities are probably exaggerated a bit, but many of these do work, and cost less than the individual parts would cost us to make one. The output is ground referenced which is OK, and these are probably cleaner than trying to use series wired tubes on 120 volts.
There are also several versions capable of making B+ voltage some are regulated and some are not. I have experimented with some of them, but not seriously enough to make a complete amp.
These things seem to come and go, and none of the simple unregulated versions that I bought almost 2 years ago are still listed. Neither are the Philips 240 volt inverters that I cannibalized for my 12 volt to 280 volt power supply which still works.
Tubelab, it's 5 year mission. To explore strange new tubes, to seek out new circuits and topologies, to boldly go where no tube has gone before......
Old 16th May 2018, 03:47 PM   #12
kodabmx is offline kodabmx  Canada
In my experience, unless the inverter is square wave, it'll work fine. I had a UPS that used stepped sine (looks like a wedding cake) that I had an old tube amp plugged into. With pure sine from the outlet, there was audible 120Hz hum from the outputs, but when powered from the stepped sine inverter, it was silent. Apparently it's easier to filter for the built in RC filter.
Noise: cheap power inverter for series heater stringHide this!Advertise here!
series 6.3V power supply to valve heater 02GF74 Tubes / Valves 12 4th December 2017 12:00 PM
Low Noise Tube B+ and Heater power supplies DualTriode Power Supplies 2 20th July 2017 07:44 AM
How do I calculate shunt resistor value in a heater series string Wigwam Jones Tubes / Valves 15 11th September 2015 03:55 PM
What is the ideal low-noise heater power for high-power output tubes? cyclecamper Tubes / Valves 37 18th January 2013 07:45 AM
String noise/squeek Robert Kesh Instruments and Amps 10 17th January 2013 05:46 PM
