Sansui SP-150 Speakers : What power needed and amp style (SE vs PP)
Old 17th May 2018, 12:31 AM   #11
Lingwendil is offline Lingwendil  United States
Now with high-fructose ASSAULT-gluten!
Lingwendil's Avatar
SE is a waste of a good 300B if you expect it to provide decent bass response out of anything other than some physically large horns with very efficient drivers, been there, done that. Push pull AB1 or AB2 300B, tetrode connected 6L6, or a triode connected KT88 AB amplifier would be pretty much spot on if you want a good all-around amplifier capable of most anything you ask of it at that sort of power. Bass requires power and decent output impedance to sound accurate.
Leave poor performing SE to the golden ears that drink expired wine while listening to LPs by candlelight. That, or run a separate subwoofer
( I better board my windows, deadbolt my doors, and keep a rifle handy tonight, I fear what I spoke may be heresy to some of the members here! )
Check out My 6SN7 Push-pull Flea Amplifier project! PCB COMING SOON!
Old 17th May 2018, 10:05 AM   #12
gug42 is offline gug42
Hello,
Thank you, It seems that somes points goes in this direction ...
I tried to evaluate needed power with SPL and sensitivity .... but I'm really not comfortable to handle thoses data ...
- Let's start with with a SPL of : 80 dB
- I will be at 1,5 or 2m.
- Power peak seems to be at +10 or 20 dB from the average... so let's say 95 db @ 1,5 m
- Let's says my room is not treated ... so very little absorption, well so max 100 dB @ 1m
- With speaker of 95 dB / w / m, I need + 5 dB hum ... that's the point ... : to convert 5 dB in Watt ?!?
Ok I have read : to have +3 dB, the must be double. So for speaker with efficiency of 95 dB / W / m ... onyl two watts ?
And 80 dB SPL seems to be prety loud : Sound pressure - Wikipedia
Thank you in advance !
Old 17th May 2018, 11:08 AM   #13
azazello is online now azazello  Bulgaria
azazello's Avatar
1-2 W from amp 3-4 W sounds better than 1-2 W from amp 30 W....except If You want to break the furniture, windows....
Projects: SE GK71, SE 12BQ6, PP KT88, OTL-OCL 6AS7 Gen. Electric, SEs 2A3 RCA, 300B JJ, 6S4S, 4P1L, EL11 Telefunken, 6AS7 RCA, 6S33S, 6S41S, 6S19P, E84L Siemens, E236L Telefunken, headphone ampl. OTL Loftin White 6AS7 RCA,...
Old 17th May 2018, 01:31 PM   #14
Well indeed for sure ... lot's of people says (and some on this thread), says that a SE 300B can't have good bass with thoses types of speaker (ie not high efficiency huge boxes).
I have done other calculation.
If I'd like to listen louder, well 85 dB SPL at the listen position. It could be 105 dB at one meter.
- With efficiency of 95 dB / W / m, I will need +10 dB. So 10 watts power.
- With efficiency of 90 dB / W / m, I will need +15 dB. So 30 watts power
More over, I have some doubt about the datasheets of the loudspeaker .... at least I doubt than the annonced efficiency could be for all frequencies ... from 20 Hz to 20 kHz ...
Did you think than Davis stentaure have 95 dB / W / m at 40 Hz with two 17cm woofers ?
And for the sansui, same question 98 dB / W / m at 40 Hz with the woofer and thoses boxes ?
And well is a "classical" 300B SE can really produce the needed powers at 40 Hz ? At least 5 Watts (10 watts will be better of course) at 40 Hz ?
Thank you in advance.
Old 17th May 2018, 07:49 PM   #15
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Not at all, if you are listening to good recordings. You are right, if you play a solo guitar.
However, when you play highly compressed music, you do not need headroom, but what's the point in tube amps for such a music? Class D amps do it better.
According to the graph on the datasheet above, your Sansui has -20 dB on 40 Hz. How much power do you need to boost 20 dB on 40 Hz?
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 17th May 2018, 09:20 PM   #16
Wavebourn, you are right ! Damm too much will be the answer .... So 30 Watts could not be enough ... and PP UL .... thx
Thank you evryone.
Old 18th May 2018, 11:32 AM   #17
azazello's Avatar
Mmm, solo guitar sounds better on big power /You are musician/! But for good simph., string, soul, jazz music, IMO, is enough about 2 x 2 W - quality SE with good freeq. band is for listening for a much hours. And these Sansui have posibility for big bas sounding. High sensitivity speakers are for this goal! Small power for big rooms. Do people need big power, that never will use more 5-10 min and damage ears? /I have PP KT88 and SE 2A3 RCA and +++ are for second, acc. my frends opinion, but alwais I use 1 W SE EL11 Telefunken in triod with cool OTs, that is the best tube for all the times, IMO....I like SE, but this is another beer...PP is for breaking the sinks.../.
If You need a big power, You can make SE GU, GK,GM....Doesnt enough to be technician, can be meloman and audiophil!
Sansui SP-150 Speakers : What power needed and amp style (SE vs PP)Hide this!Advertise here!
Sansui AU-70 - Help Needed Dev0n Tubes / Valves 8 12th August 2014 09:40 PM
Sansui 500A Power trans needed... Midnightmayhem Swap Meet 0 22nd June 2013 11:17 PM
Port style info needed please. CLS500 Subwoofers 14 9th April 2013 08:06 PM
P.A. style speakers dvdwmth Multi-Way 19 5th September 2004 05:06 AM
Bose style HT speakers Rarkov Multi-Way 20 20th February 2003 04:01 AM
