6N2P-EV vs 12AX7
6N2P-EV vs 12AX7
Old 25th April 2018, 03:07 PM   #21
Lingwendil is offline Lingwendil  United States
Now with high-fructose ASSAULT-gluten!
Lingwendil's Avatar
6N2P-EV vs 12AX7
The 6N2P has slightly lower plate resistance, and this will effect it's output impedance and therefore the frequency response when used in RIAA or other active filter stages when used in some circuits expecting to see a 12AX7.
Check out My 6SN7 Push-pull Flea Amplifier project! PCB COMING SOON!
Old 16th May 2018, 05:20 PM   #22
spaceistheplace is offline spaceistheplace
spaceistheplace's Avatar
6N2P-EV vs 12AX7
Default 6N2P-EV vs 12AX7
Thanks for that. My use case is in an RIAA stage as above.
I noticed some audible difference as I believe cyto mentioned (I didnít perceive it as good or bad necessarily- was a brief test), and wanted to understand why. I thought either just normal tube variance or my mind was playing tricks / I was victim of my own bias. But there seems to be some differences that have been discussed that could change real operating parameters.
Iím wondering how best to adapt a 12ax7 riaa stage for use with 6N2P.
The real aim of music is to co-ordinate the minds of the people into an intelligent reach for a better world and an intelligent approach to the living future.
Old 16th May 2018, 05:27 PM   #23
kevinkr's Avatar
6N2P-EV vs 12AX7
The answer is different depending on whether you are using passive EQ or EQ in a feedback loop.
For passive you will generally need to compensate for the change in rp unless it is very small and the network is insensitive to small variations in source impedance.
For feedback based EQ the situation will depend on the effect the substitution has on the overall closed loop gain, some minor changes to the design may address or adjustments to the feedback network may be required.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
6N2P-EV vs 12AX7Hide this!Advertise here!
12ax7(ecc83) and 6n2p 12ax7...........differents?? plig88 Tubes / Valves 2 26th January 2013 08:14 PM
Can I use a 12AX7 with CT 6.3V? Troncones Tubes / Valves 23 3rd March 2011 05:10 AM
12ax7 nigelwright7557 Tubes / Valves 6 1st June 2008 02:54 PM
12AX7 how many is enough? Sambeaux Tubes / Valves 19 23rd March 2007 07:31 PM
12ax7 Matthewong Tubes / Valves 0 12th June 2005 04:54 PM
